Old 09-25-2010, 12:21 PM
jhendr3702's Avatar
Default 02 300 tranny
was riding today with a bud who has a 02 300 and just riding along all of the sudden the back wheel locked up.. he said it was very hard to get back to neutral, but it did.. we stopped and he went and got his trailer and took it home..
do these have tranny issues like that ?
Old 09-25-2010, 01:35 PM
randy randy is offline
Thumbs up tranny
my 99 300 had an issue! it would either stay in one gear or not go in,,,it had VERY low miles and before i split the cases and checked shift forks and such i noticed a lot of play in the shift shaft! pull and push it to see if you have the same scenario! what i did was cut a small piece of p.v.c. tubing and installed it between the shifter itself and case (kinda float it in there)! cut it a lil smaller so it doesntpush against the seal or the shifter! after i did it i rode the bike for the rest of its life like that and never had another problem! not sure if thats your issue but it may help you! good luck and git 'er goin!
Old 09-29-2010, 06:23 PM
Sticking shift scorpion, not uncommon, will cause a no shift condition. I always remove the shaft on a new bike and check/deburr the parts as they are stampings. Locking up is something else and very rare. The early bikes used a plain bearing trans design but even those were generally good. The trans itself is very sturdy, I've had a few apart including a high hour 125 and all looked new.
Old 09-29-2010, 06:33 PM
einsteingarage einsteingarage is offline
I would check to see if the impeller shaft exploded. Mine did the same thing this weekend. I took it apart and found that there was a hole in the inner clutch cover and the shaft and gear was mangled on the water pump.
Old 09-30-2010, 05:11 AM
jhendr3702's Avatar
will pass those along... i had never heard of one doing that either..
in talking to him, he said it shifted weird a couple of times that day..
esp hard to get into neutral..
thanks guys..
New tranny technology lankydoug Enduro Engine - 2 stroke 4 09-23-2010 05:34 AM
milky tranny fluid skid jackson Enduro Engine - 2 stroke 62 06-12-2010 06:54 PM
Tranny Filler Plug Rick Enduro Engine - 2 stroke 20 03-08-2010 04:08 PM
Tranny oil for 00 GG 250 MC? scarylarry Enduro Engine - 2 stroke 7 08-05-2008 07:11 PM
tranny steve Enduro Engine - 2 stroke 2 03-26-2008 12:56 PM
