Old 02-06-2013, 03:17 PM
Scar13 Scar13 is offline
Default Which Brake fluid?
On the 2010 ec250 My res says dot 3 or 4..
Can I get use some from autozone or is a specific race version required?
Old 02-06-2013, 03:39 PM
noobi's Avatar
noobi noobi is offline
Yes, dot 4 is dot 4.
I'd say go for one made by a reputable lubricant company.
To make it more confusing, you could use dot 5.1, but not dot 5.
As a rule of thumb, the higher the dot rating, the higher the boiling point.
Old 02-06-2013, 04:27 PM
I just did mine the other day after all this discussion and mine being over due for fresh fluids. Like Noobi said. Any bottle that says "for use in DOT 3 or 4" will cover it. I just purchased from supercheapauto and ended up with Castrol racing which I think is actually a DOT 5.1 spec.
Old 02-06-2013, 07:38 PM
Cruiser Cruiser is offline
A good 4 or 5.1 is good,, cheap 3 boils too easy if your a brake dragger. I actually use John Deere dot 4 and I do not overheat the fluid anymore. I even overheated some "racing" fluid. Yes I do drag brakes on occasion.
Steve
16 Beta 350rr
04 KTM 525 sx/exc gone
03 GG 250 ec-gone
97 GG 250 ec Gone
New Brake fluid theexception_03 Enduro Chassis & Body 4 10-18-2012 04:30 AM
Clutch Fluid Help newgaser Enduro Engine - 2 stroke 12 03-14-2012 02:54 PM
DOT5 brake fluid in AJP cluch MC alecsstefan Enduro Engine - 2 stroke 12 05-25-2010 01:30 AM
Clutch... Brake fluid? roostafish Enduro Chassis & Body 6 12-13-2009 04:13 PM
How much fluid and pressure and sag? gasser Enduro Suspension 0 04-16-2009 02:16 PM
