Old 05-06-2019, 02:27 PM
GG221 GG221 is offline
Default AS3 bendix cover 2018
Does anyone know if the AS3 bendix cover is machined properly or if it is the exact same as the OEM cover? Wondering if I would need to polish the hole where the bendix shaft sits like I had to do with the OEM cover.
Old 05-06-2019, 04:13 PM
GASGASCWB GASGASCWB is offline
I use the AS3 BENDIX COVER!
Perfect!
Plug and Play.
Old 05-06-2019, 11:50 PM
Do you have a link to it?
Old 05-07-2019, 12:49 AM
shawbagga's Avatar
Just google AS3 Performance mate.
'18 Gasgas XC250
Old 05-07-2019, 06:40 AM
Cheers matey!
Old 05-07-2019, 08:48 AM
eralha eralha is offline
Why did you had to polish the oem bendiz cover? i'm having problems with the starter i tried every thing i could came across.
Old 05-07-2019, 09:49 AM
http://www.gasgasrider.org/forum/sho...t=23150&page=7
Start with post #67 and read through the rest of the posts. I tried all of the updates too and nothing worked until this. It seems to have been a problem for quite a few people. Basically there was a batch of bendix covers that got machined improperly and isn?t allowing the bendix shaft to rotate like it should. It?s a very simple fix, the only thing you?ll need to buy is a bendix cover gasket because it might rip when you take the cover off.
This was the reason for my question in this post. Wondering if the as3 cover was machined to the correct tolerance or if it is an exact copy of the covers that don?t fit.
Old 05-08-2019, 10:49 AM
thanks for the info i was starting to suspect that, i did no tsee any reason for the mechanism to not work well, mine looks like it is jaming for some reason.
I will try your solution. cheers.
Old 05-09-2019, 10:16 PM
GasGas's Avatar
GasGas GasGas is offline
Mine did not start on the button worth a pinch last year, but after a bunch of winter riding it seems to have broken in and start like fire all the time now. I expect the cold temps played a roll in wearing in the bendix cover.
2018 EC 300
Old 05-10-2019, 04:26 AM
Hi, i polished the cover and still nothing... i'm starting to give up on this.
The starter does only this: https://onedrive.live.com/?authkey=%...129763&o=OneUp
I tested it with another battery, so the problem is not the battery, i did the wire mode, larger wires for positive selenoid and starter negative.
Could it be the starter motor?
cheers.
2018 ec 250 clutch cover Leelee Enduro Engine - 2 stroke 3 02-13-2019 04:11 PM
Weak clutch disc cover, EC 2018 eralha Enduro Engine - 2 stroke 11 12-18-2018 03:46 PM
Rekluse Clutch Cover for 2018 MY Jacob 'Berg Enduro Engine - 2 stroke 10 05-30-2018 07:32 PM
bendix help Mostin3 Enduro Engine - 2 stroke 0 10-09-2017 05:48 AM
