Old 02-16-2014, 10:29 AM
ks9mm ks9mm is offline
Default 02 ec 250 starting problem
Hello gang,
Trying to help out friend of mine who just got 02 ec250 and has a hard time starting it.
Bike will start after some serious kicking. Will always start. But Hot or cold it will take some serious kicking. Choke does not make it easier to start when hot.
It will idle fine, but that can just cut of. Very abruptly. Raising idle does not help. But i did not raise idle to screaming levels. It will idle fine and then just cut off.
Once moving, it's a beast. Hard to keep front wheel down. Seems to have almost same amour of power as my 300.
Headlight is always off.
I would appreciate any suggestions.
Thanks a lot!
Old 02-16-2014, 11:39 AM
have you tried to clean the carb and make sure its set up correctly ie slow jet main jet. clean the filter too
try a new spark plug just eliminate that em some time if the ring are worn they become hard to start like my bike did.
just some ideas for ya
03 ec300
honda cr500 94
Old 02-16-2014, 11:48 AM
hamilton's Avatar
hamilton hamilton is offline
Check the reeds also.
15 GASGAS EC 250
19 Sherco SE 125R
Old 02-16-2014, 11:52 AM
Thank,
Will try to take it apart and clean out and put new plug in. Old plug looked pretty good to me.
My concern is that it shuts of at idle. Would run ..run..seemingly fine and then just cut off, instantly.
Guy who he bought the bike from said that engine had new top end recently...but I guess it's worth taking a look inside.
What's the best place to get complete gasket kit? Top end gasket kit?
Do you think air leaks from crankcase can cause this?
Old 02-16-2014, 11:54 AM
Thanks, what should I be looking for?
Both of us are new to 2 strokes.
We switched from 4 strokes.
Old 02-16-2014, 01:28 PM
two strokes are easy mate a lot less stuff to go wrong.
you can just get a base gasket and leave the head on. did the fella give you any receipt for new pistons etc
its a carb or plug I bet ya. strip and wash the carb in old petrol and blow out with a air line if not you can get carb cleaner in a spray can.
set the mixture screw to 1 1/2 turns just pull the dial screw and check its not damaged
just a few tip and some bits to look at where in this wide would are you from
03 ec300
honda cr500 94
Old 02-16-2014, 01:40 PM
here is a manual to help with the carb http://www.gasgasmotos.es/en/manuals/models-2-2003.html
03 ec300
honda cr500 94
Old 02-16-2014, 03:48 PM
Thanks! Will try that first
Waiting for bit of a warm weather... It's freezing here in NY..
Old 02-16-2014, 04:06 PM
No worries good luck, just wondering if its so cold the bike has trouble starting ???
03 ec300
honda cr500 94
Old 02-16-2014, 04:55 PM
We rode only twice since he bought the bike, both times it was barely above freezing with snow on the ground. But above freezing. I would say no more than +5C
GAS GAS 450 SM starting problem adamos Enduro Engine 4 stroke (including EFI & Exhaust) 4 02-23-2012 03:21 AM
Starting problem SeanUK General Discussions & Announcements 2 06-25-2008 12:29 PM
04 450fse Starting problem gasser-downunder Enduro Engine 4 stroke (including EFI & Exhaust) 4 04-25-2007 05:54 PM
03 400fse starting problem smnl4l Enduro Engine 4 stroke (including EFI & Exhaust) 3 04-15-2007 10:20 PM
starting problem Dicko Enduro Engine 4 stroke (including EFI & Exhaust) 8 03-06-2007 04:16 PM
