Old 02-19-2008, 12:21 PM
GG27 GG27 is offline
Bike year & model = '08 EC250
Temperature (degF) = 50-65
Elevation (feet) = 0-700'
Main jet = 178
Pilot jet = 42
Needle & notch = N1EG #2
Air screw setting = 2
Throttle valve/slide = #7
Results: I run DENICOL S2 @ 50:1 , no other engine mods. It idles nicely and pulls up front wheel in 2nd and 3rd when snapping the throttle. I'm still playing about with the settings just to increase low end response. I got a cck needle just to try it out.
Old 02-19-2008, 07:04 PM
Eric K Eric K is offline
Bike year & model = 2006 EC300
Temperature (degF) = 30 - 40
Elevation (feet) = 0 – 500
Main jet = 185
Pilot jet = 40
Needle & notch = CCK 3
Air screw setting = 0.5
Throttle valve/slide = 7
Results:
This is my lower elevation winter setting. Throttle response is great and the engine runs very strong from idle (1100 RPM) up to 10000 RPM.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 02-19-2008, 07:07 PM
Temperature (degF) = 40 - 80
Elevation (feet) = 3000 – 6000
Main jet = 170
Pilot jet = 38
Air screw setting = 0.5 – 1.5
Results:
This is my higher elevation, summer and fall setting. Throttle response is great and the engine runs very strong from idle (1100 RPM) up to 10000 RPM. Fuel mileage is 20+ mpg on technical trails.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Bike year & model = 2001 XC300
Main jet = 182
Pilot jet = 42
Throttle valve/slide = 8
Results:
This is my lower elevation winter setting. Throttle response is great and the engine runs very strong across the range.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 02-19-2008, 07:08 PM
Elevation (feet) = 3000 - 6000
Main jet = 172
Pilot jet = 40
Air screw setting = 1 - 2
Results:
This is my higher elevation, summer and fall setting. Throttle response is great and the engine runs very strong throughout the range. Fuel mileage is 20+ mpg on technical trails.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 03-01-2008, 08:07 AM
Leon_gasgas Leon_gasgas is offline
'07 EC250, temperature around 0 C (-5 - +5), elevation 0 to 100m, 10 kms distance from sea, TTS 50:1, Unleaded super 98, 10ml ethanol additive per tank to help against carb icing, the air intakes of one of the radiator covered with tape, protection for the carb from snow and to guide warm air from the cylinder to carb boot.
Pilot: 45, 1 turn out
Needle: N1EF #3
Slide #7
Main : 185
Finally the bike runs Great! Nothing to complain about. Tiny amount of spooge at the end of silencer after 2 hours on the MX track. It rips! if you want more power then your name must be Juha Salminen )
Old 03-05-2008, 10:53 AM
Gregarious Gregarious is offline
Bike year & model = 2007 EC 300
Elevation (feet) = 200
Main jet = 178
Pilot jet = 42
Needle & notch = CEK (3 - middle)
Air screw setting = 3 turns
Throttle valve/slide = 1.5
Results:
Riding style: slow technical trails -- rarely out of 3rd gear.
Premix: Using BelRay H1R mixed about 40:1.
Only a tiny bit of "spooge" on the tail pipe after 40 miles. I'd call it "just the right amount". Not enough to be messy, but enough that you know the engine is getting lubed.
Smoke: once warm, little to no smoke at all.
Performance: very tractable, very smooth.
Rider: very happy.
Old 03-17-2008, 03:21 PM
ferguscawley ferguscawley is offline
Bike year & model = 2006 EC 300
Elevation (feet) = 0 - 1000
Location = Cork, Ireland
Main jet = 178
Pilot jet = 42
Needle & notch = N1EF clip 1
Air screw setting = 1.5 turns
Throttle valve/slide = No. 7 slide
Results:
Riding style: slow technical trails and fast open paths
Premix: Using RockOil Syn 2 race mixed about 45:1.
Performance: Excellent once warm
Old 03-28-2008, 05:15 PM
kim kim is offline
Bike year & model = '03 EC300
Temperature (degF) = 40-100
Elevation (feet) = 0-3000'
Main jet = 168
Pilot jet = 38
Needle & notch = LTR middle notch
Throttle valve/slide = #8
Results: I run BP Racegas, 100 Octane. Premix is 50:1 using Total Grand Prix 2T oil.
LTR power valve cover is fitted, Boyssen Carbon Fibre Reeds and Messico Exhaust.
Bike pulls clean from bottom with a peakiness at 1/2 throttle and revs to the moon.
Peakiness could be due to carbon reeds, will try fibre glass reeds for a more linear power delivery.
Starts first kick hot or cold, idles good (after I fitted the #8 slide).
Very little smoke or spooge.
Kim
08 TXT 300
06 Gasgas EC200
03 Gasgas EC300
05 Pampera 250
Old 04-12-2008, 12:58 PM
REVERUP's Avatar
REVERUP REVERUP is offline
Bike year & model = 2008 Gas Gas DE 300
Temperature (degF) = 45-60
Elevation (feet) = 250'- 5000'
Main jet = 178
Pilot jet = 35
Needle & notch = N1EF 2nd position
Air screw setting = 1 to 2 turns out depending on temp and elevation
Results: Crisp clean response. I run Chevron Supreme and Golden Spectro at 50:1 and my Irridium BR8EIX Spark Plug burns a beautiful tan just like that perfectly cooked camp fire marshmallow.
The jetting database needs your help! MattR General Discussions & Announcements 4 10-18-2017 05:34 PM
JD Jetting settings for linear power delivery? SpeedyManiac Enduro Intake/Carburetion - 2 stroke 5 04-06-2010 06:17 PM
Modification/Aftermarket Database SpeedyManiac Enduro Product Reviews 4 02-04-2009 07:09 AM
Jetting Database Announcement MattR General Discussions & Announcements 0 12-18-2008 08:58 PM
Jetting Database Summary MattR Enduro Intake/Carburetion - 2 stroke 0 12-18-2008 08:36 PM
