Old 03-30-2022, 05:41 AM
Cstewa37 Cstewa37 is offline
Default Ignition Coil Location - 2011 EC 250
Hi all,
Trying to rebuild my project bike back to factory as the previous owner has made a bit of a mess with it, the electrics in particular.
The ignition coil when I bought the bike was in a vertical position and only attached with one bolt (see attached photo).
Assuming this is incorrect as the top bolt in the photo doesn't connect to the frame, I can't figure out the correct orientation as the tabs on the frame don't line up with the coils mounting points.
Does anyone have any photos to show the correct layout of the coil, regulator and horn please?
Regards
Chris
Old 03-30-2022, 11:55 AM
Neil E. Neil E. is online now
That's a larger coil, probably from a different bike. The stock coil mounts on two frame tabs, one above and one below the coil body. I have photos from above and below.
Old 03-30-2022, 12:03 PM
Found a picture of the rectifier. Bolts on the left side of the sub frame.
Old 03-30-2022, 04:34 PM
Oh excellent! Thanks for sharing, that definitely explains the issue haha! Even the reg is different from yours, this project is full of surprises! 😂
Chris
Ignition coil question, EC300, m.y. 2009 Mikeyx Enduro Electrical & Wiring 12 07-25-2020 12:00 AM
Ignition coil Gassedshaun Enduro Electrical & Wiring 0 12-24-2017 04:35 AM
2005 (maybe other years) ignition coil Vinny Parts 0 09-21-2016 11:58 AM
Ignition coil davedunaway General Discussions & Announcements 2 09-04-2012 12:22 PM
