Old 09-15-2008, 12:44 PM
clerky clerk clerky clerk is offline
Exclamation Slow Gas Gas Ec300 help!!!
Does anyone know what could be wrong with my ec300 it seems underpowered it doesnt want to wheelie no matter how much stick i give it. The compression seems good as it is hard to kick and it runs well and rattle free (as rattle free as a 2 stroke can) The reviews I have read make out as though it is meant to be an animal, this sure is not, please HELPPPPPPPPPPPPP!!
Old 09-15-2008, 12:55 PM
ferguscawley ferguscawley is offline
Tell me more - what year is the bike ?. is it brand new or used ?. Waht exhaust does it have ?. Have you looked at the powervalve to see if it is working ?
Fergus
Old 09-15-2008, 02:24 PM
Please keep this in one forum. This is fine and I will delete the thread in the General forum. As was stated please provide more info, thanks.
Old 09-15-2008, 03:11 PM
2 strokes 4 life's Avatar
Air fliter, clean carb, proper jetting, changed oil, powervalve, spark plug, ignition and many other things could be wrong. Please, we need more info.
2012 Ktm 300xc
2001 Gasgas EC300
Old 09-16-2008, 01:28 AM
Smile Slow gas gas ec300
Hi and thank you for your assistance. The bike is a 2001, it has recently had a top end rebuild (small end bearings etc), I have just recently changed the plug, appart from that it is as I bought it. Where will I find the power-valve and how do I check if its working? I will look at the exhaust model when I get home.
Is it right in saying these bikes are one of the quickest, as I cannot stand with a yzf 250 4stroke at the moment!
Old 09-16-2008, 02:47 AM
Bearman's Avatar
Bearman Bearman is offline
What gearing have you got on it?
Ben
'03 GasGas EC200 My bike
'89 Yamaha TT250 R.I.P - Lost in the Black Saturday Fires
Old 09-16-2008, 03:36 AM
Was the top-end rebuild done by somebody competent ?. There is a possibility the piston may have been installed wrong way round. There is also the possibility that the powervalve actuating rod is not properly attached to the powervalve itself.
To check powervalve operation, remove front exhaust pipe, then remove small cover on right hand side of engine (3 bolts hold it in place). Replace exhaust pipe and start the bike. When revving the bike, you should see the powervalve actuating rod moving up and down with revs. If not, then it is most likely the little grub screw that clamps this rod in place is loose (you will need to replace right hand side engine casing to fix this).
Go to the gasgasmotos.es site and download a manual for free and have a look at it. it will help greatly.
Fergus
Old 09-16-2008, 06:17 AM
Default Slow Gas Gas Ec300
Im unsure as to what gearing? its all standard.
Old 09-16-2008, 06:29 AM
Thanks Fergus.
Old 09-21-2008, 08:03 PM
Wicitup's Avatar
Wicitup Wicitup is offline
Check the silencer and make sure it is not plugged. I have a friend that we think that this is a problem with his ec300.
this will slow me down a little.... jhendr3702 Pictures & Videos 44 10-07-2010 01:29 PM
2005 EC300 vs 2007 EC300 alecsstefan Enduro Engine - 2 stroke 19 01-22-2010 01:40 AM
