#21
Thanks for the title change moderator!
2003 EC250 w/ Ohlins pkg Sometimes you eat the bear, sometimes the bear eats you. |
#22
http://www.gasgasrider.org/forum/sho...79&postcount=7
This is for 70deg.F below 1000ft. IIRC what was in there previously was 178 main, but 38 pilot and a N1EF needle. Of course YMMV. Check out post #27 on this page: http://www.gasgasrider.org/forum/sho...?t=1414&page=3
Ross '05 MC 250 '91 Husky 610wxe '04 Duc M800 R.I.P '06 Duc S2r 1000 R.I.P '07 Duc S2r 1000 still rubber side down... ---------------------------------------------------------- May be so... May be not so... My Website |
#23
That hilarious that it was in this thread. I guess I should re-read my old threads when I go to bump them ahahaha.
I got a 10 oz FW weight on order, so hopefully that will be enough to help with the PV cover. My jetting is similar to yours, so that works :-) I might swap the CCK in for the DDK, but it feels pretty frikken good right now. BTW- Your furniture is really awesome.
#24
Got my new pegs on this weekend, cut the bars down, re-mounted my handguards with new hardware.
Got the flywheel wieght and PV cover. Hoping to put them on tonight along with Radiator Guards. Been a good time for downtime cause it's been raingin non-stop. Stupid question- which side of the case does the flywheel weight go under??? Gonna take pics tonight so I can get some more details on what I need to do for a rudimentary lighting setup.
#25
The FWW goes on the left side. FYI you should pull the ignition cover after every ride and make sure there is no moisture/water in there. The covers generally let water in.
I still have not forgot about the wiring of the lights. I'll take a look soon and get back to you.
2004 GasGas DE250 |
#26
#27
Nope, no oil under the black plastic cover.
2004 GasGas DE250 |
#28
Sweet, maybe if I get my forks back I can take a rip tonight and see how the mods feel.
#29
Alright. So last night I went about the following items-
Install radiator braces. Holy crap the radiators were mashed in enough that I am surprised they weren't leaking. I had to gently work them back out so that the braces would fit. They are now on. Yeah for more guards. Tried to get flywheel on. Guess I need a bigger impact because my little cordless jobby couldn't break it loose. It's currently soaking in a little PB blaster. Installed my Gofasters PV cover. Drained coolant. Can't get the water pump cover off although that's not a huge surprise. Not sure I am that concerned about it at this second. If I can get hardware I might be able to get my forks back on tonight or tomorrow (damn lawn getting in the way of my bike). Pics- Stator Side with covers off- Clutch/Waterpumpside- From back when I tore it down-
#30
$200 XR70-
Tow vehicle-
23 Machine Test | HuskyDude | General Discussions & Announcements | 3 | 04-26-2010 03:42 PM |
New England Triple B run | Skidad | General Discussions & Announcements | 4 | 06-12-2008 10:54 AM |
Machine the barrell? | rupecopp | Enduro Engine - 2 stroke | 1 | 04-24-2008 06:39 AM |
Gas Gas in New England | Skidad | General Discussions & Announcements | 8 | 12-27-2007 08:24 PM |
New Member Intro... | flan8tive | General Discussions & Announcements | 0 | 02-02-2007 11:04 AM |
