Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > GasGas Member Polls
GasGas Member Polls Find out what everyone thinks about it!
Old 11-24-2015, 08:58 PM
gg3's Avatar
gg3 gg3 is offline
Originally Posted by NZMark View Post
Castrol TTS @ 50:1 works mint in a 300
Stay away from Motul 800 in anything over a 200 it works best in 80,s & 125's on a MX track
Changed from Motul 800 to 710 & got less spooge dribble.Ran out & used a mates Castrol TTS & have stayed with it.The dye is easy see once mixed(Did I mix this gas? Yeah,nah,Yeah,not sure,put it in the wifes car to be safe).
Old 11-24-2015, 09:42 PM
barossi73's Avatar
its also easier to see thru the "transparent" tank sides,smells decent,and only drools enough to let you know that some oil survived the burn.ideal
2013 ec200r
Old 11-24-2015, 11:38 PM
paulos paulos is offline
+1 on the TTS. I remember when i was a kid the TTS was in a trick can. I could only afford the Super TT povvo bottle.....
2011 Gasgas EC200, 1966 BSA 350 scrambles, 1972 Montesa cota 247
Old 11-25-2015, 02:07 PM
NZMark NZMark is offline
Yer same mate
When I was a youngster TTS was out of my price range
But I've been running it since my IT200 days
Old 06-27-2016, 12:39 PM
stian stian is offline
May be and old thread, buy does anyone know about bendzall 460 "green label"? Its a castor oil.
Firm sold it as a final-sale due to closing the Shop at 3,60? / liter. The oil is widely used in karting,as the klotz and maxima 927, al being castor-based.
Castor tends to gym up rings and PVs, and maybe i should mix the bendzall with other synthetic oils in the premix?
Old 07-10-2016, 08:11 AM
Getoviq95 Getoviq95 is offline
I use 2t cross power from Motorex ,one of the best oil for me .
Old 07-10-2016, 03:21 PM
FastFast's Avatar
FastFast FastFast is offline
Opti-2@50:1
I'm part of a maintenance team for non-automotive equipment in a municipality of over 1 million people. We have hundreds of 2 stroke implements that are used in terrible conditions. Rescue saws, urban forestry equipment, etc. The stuff used for emergency utility repairs are absolutely brutalized, premix ratios are often close enough, these are machines that are often full throttle the moment they start. -35C to +35C, rain, snow, mud, occasional partially submerged use (not kidding). Other machines are WOT through multiple tanks of fuel all day, week after week. Although the machines are spec'd for 50:1 we use them at 70:1 successfully per Opti's claims. It's thousands of hours each year of hard use and I have yet to see a machine fail, or wear out early, because of oil related performance. This experience quantifies the oil as a good performer to me, and I suspect it's good enough to run in my dirt bike
Old 07-16-2016, 12:30 AM
Nocams Nocams is offline
GRO off road 1 for me in my 15 ec300 @45:1 and my 11 txt300 @80:1.
My old 2010 ec300 sold with 565hrs without crank work,only top ends every 100 hrs.
I'm sticking with it!
Old 08-05-2016, 02:17 AM
(F5) (F5) is online now
Wet Stuff pleasure lube.
You have to run it 4:1 and it cost $30 for a 100ml tube but c'mon, what price sangfroid imperturbability?
Old 08-05-2016, 04:45 AM
KMA KMA is offline
Originally Posted by shang View Post
I had been using one of the Maxima oils but changed to Motorex to see if it cut down on the spooge. Then I found out my PV drain was closed. After opening that there's no more spooge so I went back to the maxima.
I get a deal on it through a friend, but the biggest reason I like maxima is because when I did a 30 mile ride through super technical rocky single track with no coolant in the bike, when it did finally burn down on the road back to the truck, it melted the piston, turned the wrist pin blue, melted the spark plug, but never seized. Everything still had a sticky coat of oil on it. I think that's pretty cool.
I have a 2012 250EC. Where is the PV drain?
What is your favorite GasGas engine size? MattR GasGas Member Polls 51 09-11-2014 10:12 AM
Favorite picture of yourself on your GasGas. GreatBritishRob Pictures & Videos 43 10-07-2011 08:07 PM
favorite clamps for oversized bars motogroove Enduro Chassis & Body 0 05-16-2011 07:42 AM
Put a few of my favorite pics up on the website.... Steve@Motowest Pictures & Videos 0 07-14-2009 08:05 AM
