Old 08-03-2012, 03:04 AM
Default Moose Sahara vs Klim
I have been using Klim kit for quite a few years now, but considering getting a set of Moose Sahara kit, just wanted to hear if any of you have any comments on the moose kit
I think it is slightly cheaper than the Klim Baja kit so want to know if it is similar in quality, comfort and also size? thx
Old 08-03-2012, 05:46 AM
stainlesscycle's Avatar
i have a set of 2012 sahara: true to size. cut/sizing just like other moose jersey/pants. quality is good, jersey is definitely lightweight and flows air well. showing wear on knees from thor knee guards -all my pants rip at same location. - it's pretty much about the same as all the other decent quality level stuff. pants flow ok, but i bet the baja flows more air. seems like it will last as long as all the others (which is not long enough). i'd like to try the klim baja to see if it's any better...let us know.. i rotate through 3 sets of pants/jersey - moose xcr 2011, fox 180 2010, and sahara 2012. even though the fox 180 stuff is less expensive, i bet it outlasts the other 2.. i buy 1 set a year, and get rid of the most beat up set...
07 ec300
www.stainlesscycle.com
Old 08-03-2012, 05:55 AM
Cruiser Cruiser is offline
I have the new klim jersey and it does not flow that well.. I'm looking to try the moose jersey myself..
Steve
16 Beta 350rr
04 KTM 525 sx/exc gone
03 GG 250 ec-gone
97 GG 250 ec Gone
Old 08-03-2012, 06:26 AM
johnnyo johnnyo is offline
I have had the Sahara gear now for over a year. I will probably get a new set soon and I would get this again. It has worn as well as everything else I've had. Sizing is true, and the airflow is great. I would recommend it.
I do admit that I have not tried the Klim's to give an unbiased comparison but would dare say you won't be disappointed with the Sahara.
Old 08-03-2012, 06:53 AM
Longevity is one of Klim's strong points, i have two sets that i rotate and one set is from 2006, granted it is not going to win any beauty contests, but only a few small holes from a few hard falls, but still keen to give the moose a try
if you wear 34 jeans will the 34 moose fit? It seems to be the biggest complaint abpout moose kit is that the sizing is not right
Old 08-03-2012, 07:32 AM
pants might run a tiny bit small. i'm 185lbs, 5'11" tall, i bought 36 pants, xl jersey, as i like a bit loose fit on jerseys.. fits fine, maybe a slight bit tight at knees if you wear braces. regular guards should be no problem. the ankles are not cut tight like other pants (the tight cut ankles are so annoying when taking them off)
07 ec300
Old 08-03-2012, 08:15 AM
I have two sets of Sahara gear, it works very well. I think they are close to true size and did not notice a problem, plus they have the velcro adjusters on the waistband. One set of pants are worn through at the side of the knee from the knee guard, but that will happen to any pants two years old. Good stuff, I'll buy another set for sure, but I need a new set of cooler weather gear first.
Old 10-19-2012, 06:02 PM
celler celler is offline
I have had various sets of Moose Sahara. I always wear through the knees. I bought a set of Klim and also wore through the knees. I will buy Moose again since the extra cost of the Klim did not make the knees last any longer. I had a pair of Sahara with the kevlar knees and the were the best I had off any pants so far. To bad they changed the design.
Old 10-20-2012, 07:11 AM
I did get a new sahara jersey, sad part is its past the warm weather so cant compare it really.. but its obvious just holding it up to the klim jersey the venting is way better. The klim Has much smaller vent holes but the sahara is so vented its transparent in places..Next step for jersey for more vented would be a paintball jersey. Some of those are wide open mesh on the sides and under arms.. May try the vented pants next summer too..
Steve
16 Beta 350rr
03 GG 250 ec-gone
97 GG 250 ec Gone
Klim scramble pak?? desertgasser300 Enduro Product Reviews 6 05-01-2012 01:56 AM
Klim pants. Who wears them? firffighter Enduro Product Reviews 15 06-06-2011 01:40 AM
Klim F4 Helmet stockist Qui-gon General Discussions & Announcements 0 07-23-2008 08:19 PM
