Old 03-01-2013, 05:07 PM
nknudsen's Avatar
nknudsen nknudsen is offline
Default What fender with Yamaha KYB SSS forks??
I'm gathering parts to do the Yamaha fork conversion on my EC250. What fender do most use when converting to KYB forks? Has anyone modified the lower triple clamp to mount the 2011 type fender? Pictures are welcome! Thanks!
Noah
Old 03-01-2013, 06:47 PM
I'll be posting up my conversion here pretty soon.
Since you asked, here's what I did.
I ground down the two bolt lugs on the front of the 3X clamp. Took a die (8mmx 1.25) and cut threads on the two vertical pins on the clamp.
I drilled two new holes in the GG fender-1/2" aft of the OEM holes. Then I made an L bracket to mount the front of the fender to the Yamaha clamp. I reused the two front holes in the GG fender.
Old 03-01-2013, 07:51 PM
nknudsen's Avatar
Great idea! Thanks for the tip.
Old 03-01-2013, 07:59 PM
You're welcome.
Took me 2hrs to get this done. Most of that was trying different things to make the OEM GG fender work. The bottom of the headlight is moved foward about an inch. No big deal.
Old 03-01-2013, 08:36 PM
nknudsen's Avatar
Is your tire fairly centered in the arch of the fender with this mount? Would you've done anything different?
Old 03-02-2013, 12:40 AM
Do you need to use yz triple clamps or can you just slot the kyb into the GG ones with yz wheel and brakes?
Old 03-02-2013, 09:11 AM
pierce's Avatar
pierce pierce is offline
i just bored my gas gas upper triple clamp to the size of the kyb fork on my 2010 sachs equipped that way i could retain my factory steering stops. with out the the stops you can very easily bend the upper fork tube in a wreck.
Old 03-02-2013, 09:56 AM
The arch looks good. Does not look like the tire would rub.
The easiest option would be to use a YZ front fender.
Old 03-02-2013, 12:56 PM
Maintaining fast steering means maintaining the stock offset. The YZ parts do this. Mix and match and you lose it.
Sent from my iPad using Tapatalk HD
Old 03-03-2013, 07:46 AM
So you saying the yz front end slips right into the GG 3-clamps?
Yamaha no more Beta Steve General Discussions & Announcements 11 06-18-2012 06:04 PM
CCM + Yamaha Rick General Discussions & Announcements 0 06-25-2009 12:30 PM
450 FSE = Yamaha MtnRider Enduro Engine 4 stroke (including EFI & Exhaust) 1 08-17-2008 01:32 PM
Gas Gas 450 vs Yamaha WR test Skidad General Discussions & Announcements 2 05-08-2008 06:35 AM
