#11
So I presume it was the oil (it only had 3 rides on it tough). p.s. I bent the right radiator and it's leaking now on high revs, need to sort it out this week
'14 EC300 |
#12
And witch tipe of oil do you use now?
#13
Motorex gear oil 10w30 synthetic performance, I don't usually buy this brand. I have also tryed Yacco semi-synthetic 2t 10w30 and Motul transoil 10w30 (both cause squeaks on high temp).
p.s. I did have great results with the old Motul transoil semi-synthetic, the one with the red and white sticker on it, but now all you can find is the one with the blue sticker witch is mineral.
'14 EC300 |
#14
No ATF try?
#15
I've used a mix of 10w40 and ATF with good results, for the same squealing clutch issue.
2012 xc300 - Great bike! sold looking for 18+ |
#16
10w40 for cars or for bikes?
Yes my Clutch does drag. | (F5) | Enduro Engine - 2 stroke | 42 | 04-09-2019 12:11 AM |
Clutch drag is doing my head in !!!! | Packman | Enduro Engine - 2 stroke | 9 | 06-30-2013 03:59 AM |
Clutch drag.... | BluegassXCR | Enduro Engine - 2 stroke | 3 | 07-04-2011 03:27 PM |
Does your clutch drag? | stay_upright | Enduro Engine - 2 stroke | 11 | 06-05-2008 03:14 AM |
Clutch Drag? | Gas Huffer | Enduro Engine - 2 stroke | 5 | 12-11-2007 05:02 AM |
