What ever have i bourght
Hi there. I'm fixing up a mc250, or so i thourght, looking at a 2003 manual i seems that the engine oil filler bolt would indicate it is a 125, how do i find out what and from when the gasser is? Is there anywere i can cross reference the vin/engine number and find out.
Post a pic of the motor. Vin on the bike should start vtrec125 or something. Post the start of the vin.
2013 GasGas 300 2004 GasGas 200 2011 GasGas 300 Ortonville Minnesota |
There are a ton of clues on the bike like part number on pipe, vin #, engine is a totally different casting than the 200-250-300 casting.
Its a 250 he posted a pic of the bike here http://www.gasgasrider.org/forum/showthread.php?t=17866 post #7 also has EC25 stamped on the engine.
What makes you think its a 125? The oil drain and fill bolts are the same size and small inside diameter is only 1/4 inch or so.
Sorry there is ec25 stamped om the engine i just read that on the 125 the engine oil fillet hole i just above the front sprocket, and it is on mine. The gear lever is very tight in movement, it slots i gear but nearly af smooth as my road bike suzuki Sv1000, is it a open and se what i bent or just me beeing anti dirt bike. Here is a picture of the frame vinuploadfromtaptalk1408294895457.jpg
It's a 250 from 1999 or so
4 strokes are only good for power generators |
Thanks Elvis, could only find a manual for a 2003, but it seems that besides the plastic that they are more or les identical. Any body know about the tight gear shift?
The gasgas gear box is tight and shifts very smooth.
Most parts will be the same from 2000-2005 on the 200,250 and 300.
Noah 2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title 16' Ski-Doo XS Renegade X 1200 4T 16' Specialized Fatboy trail 02' ZRX 1200r R.I.P. 72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been) 15' TW200 Last edited by nknudsen; 08-18-2014 at 08:25 AM. |
