Old 04-03-2015, 05:03 PM
What's the best way to test the regulator off the bike?
I'll drop a filter on the 2010 model and kick it in the guts and see how it behaves today if I get the chance.
Old 04-03-2015, 07:06 PM
Neil E. Neil E. is offline
I think you need a powerstat to really test it (variable voltage AC transformer). You could gradually increase the voltage above 14V and it should hold at about 13V - 14v. Maybe the lack of a battery highlights the problem. The battery typically absorbs small spikes.
2011 EC250E
Old 04-04-2015, 01:54 AM
rubber Jonny rubber Jonny is offline
I've tried running my bike from both white and yellow wires from the static just to see what happens. Did wonder if it had been wired incorrectly wrong colours or something. Made no difference at all.
Old 04-04-2015, 02:14 PM
Just a note to mention that my "DC with battery" diagram is only meant to show a battery for having some lighting with the engine off. It is not suitable for an estart application.
2011 EC250E
Old 04-16-2015, 05:52 PM
Checked the 2010 model, and it seems to be regulating at 15V from what I can tell (quickly checked).
I'll pull the regulator from this bike and switcharoo it. See what happens next.
Old 04-19-2015, 12:50 PM
I think it's a intermittent problem. The 15 - 20 volts you see at home are not the big issue I bet it wacks for power for a moment through everything to blow the bulb like that.
Old 04-19-2015, 06:25 PM
Mine seems pretty consistantly over volting. 20V isn't a whole load, but its also just cracking the throttle on the stand, which imo is different to holding it pinned at 9500rpm for sustained durations (something I won't test on the stand - too much noise).
Old 04-20-2015, 05:25 AM
That what I mean. Voltage will be different when riding with proper load on engine. Bet it goes over 20 when riding. 20 doesn't seem enough to shatter the glass.
Old 05-09-2015, 12:55 AM
Got me stumped. Tried a 3rd OEM reg from my old bike. Still revs up to 20V easily on the stand, and probably much further on the trail. I haven't switched the headlight back on.
I'm just gonna ride it!
Old 05-09-2015, 10:07 AM
barossi73's Avatar
would adding length to the wiring loom or using different weight/resistance wire help drag the volts down?
2013 ec200r
gasgasman's 2015 250R ride report gasgasman Ride Reports 7 04-02-2015 08:40 AM
Honda DI 250r for 2015! nambo-trev All Other Bikes... 3 04-01-2014 07:31 PM
Countershaft/Sprocket seal leaking on '12 250R Novascotiarider Enduro Engine - 2 stroke 14 04-19-2013 05:00 PM
'12 250R is in the house GMP General Discussions & Announcements 66 07-03-2012 11:55 AM
Gas Gas 300 Quad. Will 250r radiator fit? skoolball23 Other GasGas Bikes/Quads 2 04-26-2011 08:15 AM
