#11
Just checked my late model 2010 Euro EC300. Using the Air Striker II. 38 Printed in the top..
38 Pilot N3EG #1 (going to change to a N3CH #2 once arrives) 175 Main Gas Gas have finally got the bikes to a good standard, now they just need to ensure they all come either with some kind of standardised parts/sizes and some quality documentation! |
#12
I wouldn't doubt it at all! As much as I like a lot about GG this would not surprise me at all. They can be a little chaotic with build quality. Hence the early Sach suspension fiascos. |
#13
My 17 yr. old says our '11 250 6D has a 36mm cast into the carb top. I can't see too well up real close (holding out on the bi-focals). When I do put on the "reading glasses", I see a kind of odd-looking 6 that could be easily mistaken for an 8.
It's a gas hog though. We're consistently getting to the 28 mile marker then "wha, wha, whaa...whaa", we have to switch to reserve. Gonna re-do the jetting for warmer weather (yeah!). Bike runs great! I'll also check the float level although nobody seems to know what the spec is. If I was losing fuel due to the float being too high, wouldn't somebody smell some gas now and then? |
#14
I dug up a float height for the ASII on KTM Talk of 6.5mm. From Roscoe's description of the float assy I don't know how it would be adjusted though, as the tab does not sound like it could be bent. Could the entire needle valve assy be unscrewed from the carb body, and moved up with a shim washer(s) to adjust spec? If you can take this out of the carb, measure it, take a few pics, I'll find a shim for it. Just a thought.
#15
Nah. What with all the 2 stroke oils smells and that it's dropping out the overflow onto absorbant ground, i.e. mud, sand etc. Could easily be missed if you're not looking for it. The only time I've noticed is on other people's bikes when they've stopped.
#16
The new ASII does not have the little brass tabs that you can bend to adjust float height. It's all plastic. I couldn't see any way to adjust it when I had it apart yesterday. I don't really think I have a float height problem 'cause I've never noticed escaping gas unless I was laid over from a crash.
#17
I adjusted my AS 2, no problem.
#18
Were you using too much gas? What did you find and how did you adjust it?
I didn't measure mine 'cause I wasn't sure what the benchmark is. I eyeballed it. The float center line was lined up with the gasket surface when it made contact with the valve. |
#19
I did it on my friends 010 six days. He was complaining about really bad fuel economy. I had posted up earlier, with an accompanying photo that the spec I had recieved was but unable to coroborate was 6mm. I set his at an arbitrary 8 mm , mine in my new unridin bike the same as well. Due to the inclement weather we have been unable to provide any tangable results. I did however do a side by side comparisin between a AS1 and AS2 float assembly's and found them to be of similar shape and size, with somewhat different float materials being used but the major difference of the assembly's still being the depth of the float bowl's themself.
#20
Widebear,
Please describe how you adjusted the float height on the AS2. Why was the stock height a problem and what benefit did you see with less bowl volume? Did the carb run out of fuel at sustained WOT? |
300 2T Differences between 08' and 2011 ?? | husley | General Discussions & Announcements | 11 | 12-23-2010 10:31 AM |
´08 and ´09 differences? | vavido | General Discussions & Announcements | 3 | 11-10-2008 09:20 AM |
head differences 03-05 450? | Motarded1 | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 05-12-2008 01:02 AM |
head differences 03-05 450? | Motarded1 | Enduro Engine 4 stroke (including EFI & Exhaust) | 0 | 05-03-2008 07:43 PM |
Differences between DE and EC models | ScottyR | General Discussions & Announcements | 38 | 02-13-2007 06:40 PM |
