#11
Originally Posted by lineman12345678 I re-jetted it with DDK needle middle position 178 main and 40 Pilot... I am only a half turn out on the fuel screw. The farther I go out on the screw it starts to blubber. I run 48 pilot with 180 main (and LTR needle) on my 250
jeff '00 XC250 (mine) LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion. '04 EC250 (the kids) (he can do his own mods haha!) |
#12
Thanks. I was thinking about trying the 42 pilot also. With the 40 I can run it 1 turn out but 1/2 turn is much better. I think the 42 will work the best. Are you counting the needle clip position from the bottom up or top down?
It's also important that you back out and reset the idle screw - if you have it cranked in too far you are starting to "pull over" from the needle/main too early. Where is your idle screw set now? If it is cranked in to the point of coil bind on the spring - then it needs to be backed out.
jeff |
#14
Yes it is compressing the spring a bit. I will back it out when I switch it to the42 pilot. Thanks
I this weather - I would go with a 45 pilot and then turn down the idle. I would go with the LTR needle - one clip position up from center.
What fuel & mixture ratio are you using, etc. Are you running a race fuel or pump gas? You would go leaner for a race gas with a lighter specific gravity. jeff |
#16
By the way, if you want to make the carb easier to dial in - consider having the Ron at RB-Designs do his carb mod on your keihin. And to make it run cleaner (greater efficiency and throttle response) - having the squish dialed in by Ron too. He is located in Portland (actually Bonney Slope) - so is relatively local to you.
jeff |
GasGas EC500 2 Stroke - what do you think? | Keg | Enduro Engine - 2 stroke | 10 | 07-12-2010 06:38 PM |
4 Stroke GasGas questions | Trailrider | General Discussions & Announcements | 11 | 08-20-2009 10:42 AM |
NEW! GasGas EC250 4-stroke w/Yamaha Engine! | GasGasSouthWest | General Discussions & Announcements | 91 | 06-24-2009 05:53 PM |
Good GG engine mechanic | super_rat | Enduro Engine - 2 stroke | 9 | 07-30-2008 10:59 AM |
Looking For Good Gasgas Dealer | MISSISSIPPI | General Discussions & Announcements | 4 | 07-16-2006 05:24 PM |
