jetting help
trying to get me jetting dialed in...in the bike now (2010 ec300) is jd needle, clip pos 2 from the top, 170 main, 42 pilot. Im currently waiting for a gasket to adjust the preload on the PV assembly because it rattles and i will clean in while im in there because i believe it is sticking after long fast close to wide open sections (zero bottom end, trouble getting on the pipe, i shut the bike off and it usually runs fine so i believe its sticking open). So when the PV isnt being sticky the bike is clean on the bottom, and midrange, but uphill or with a load (like deep sand) it has a hard time clearing out. Downhill light load the bike runs amazing, zero hesitation, very crisp. I think i still may be a little rich but there is zero spooge and if i was rich would the high load sections require a little more fuel and run better? plug is kind of black and has never fouled although i have changed it just to rule that out. Thanks for the help!
FWW I think there was a typo on JDs sheet (http://www.gasgasrider.org/forum/sho...4&postcount=24 - second attachment) says to start with a 180 but then drops straight down to 168 for altitude. I think it should read, 178, 172,168 respectively. Move the needle back to clip #3 and drop in a larger main and then see if it'll pull up a hill any better. Do you find the engine racing or running hot as well after a run on the main jet? |
PS you never mentioned if you were running the Red or Blue needle, or what temp, altitude, etc you are running.
ya i guess i forgot that, 5 to 8k feet 70-90 degrees for temp, JD red, and yes i believe it is an AS2, has shallow float bowl and it does not have a plastic screw on top to get to the needle. I also meant to post this in the intake section, whoops! Thanks for the help Jakobi! you are the jetting guru!
In other news, I personally experienced a sticking powervalve and it stuck wide open and wouldn't come back until I manually readjusted it back, and then it stuck again revving on the stand. I'd still investigate it if you think it might be at fault. My bike lost bottom end and sounded like a bucket of bolts. It wasn't just a bit mushy or flat feeling. It felt like serious internal damage to the extent that I wasn't game to rev it hard enough to put it anywhere near being on the pipe. As stated previously, lean will be really crisp under low load but lack balls when forced to work. Will feel more like a 125. Really zippy but needs more clutch work to make it sing. It'll sound tinny/raspy and may hesitate before responding to throttle if really lean, or even stall out. Rich will burble, smoke, and won't want to take revs cleanly at all. It'll sound dull, blubbery and wet. Ideally you want some light burbling at low loads, but clean response when opening the throttle. |
ok, i will give it a go and see. I know what you mean about noise with the power valve being stuck open, although mine not to the extent you have heard. mine has a lot of noise in the exhaust pipe, lots of rattle. this bike has to be the pickiest bike to jet i have ever owned. My brother has a gas gas ec250 2010 and his bike has never even had the carb open. Runs a little fat but no hesitation at all. for some reason his also has more power than mine. leaves me scratching me head all the time
Jetting help for my 12 300 | Diggs345 | Enduro Intake/Carburetion - 2 stroke | 64 | 09-19-2012 04:15 PM |
EC 300 Jetting | Casey97 | Canada | 6 | 05-05-2011 11:52 PM |
where to go from here. jetting q. | dank | Enduro Intake/Carburetion - 2 stroke | 105 | 04-11-2011 04:25 PM |
04 ec 300 Jetting | lordfeyr | Enduro Intake/Carburetion - 2 stroke | 12 | 01-26-2010 03:16 AM |
02 ec 250 jetting help | crem55 | Enduro Intake/Carburetion - 2 stroke | 9 | 07-12-2007 01:44 PM |
