YZ 125 Cylinder on Gasgas EC 125
Hi Gasgas 125 riders, EC 125 2011-2013 is it anyone who has tried a YZ 125 cylinder on? Original or after market one?
/gasso |
I have never heard an entire cylinder could be used. You would need to confirm things yourself. Even if someone says it "fits" - you just never know how well it does so.... jeff
I have a 125 YZ cylinder here and it fit, but the hight is different and you need another cylinder head and piston. The power valve cover is different as well, here you can use the one from the 2012-2014 gasgas models
Gesendet von iPhone mit Tapatalk
4 strokes are only good for power generators Last edited by Elvis74; 03-09-2018 at 12:51 PM. |
That is very interesting information. If I understand correctly, the cylinder head and the side covers are different? There are both flat top and domed pistons that can be used in the GG and YZ cylinders depending on the cylinder head.
I think there was an auto correct or translation error. What is different ("the night")? |
The GasGas cylinder head is inside the cylinder and the YZ is flat just on top. I can take tomorrow some pictures but now it’s time to go to bed. :-)
4 strokes are only good for power generators |
So this could mean that he yz125 big bore kits will fit the GG?
I am not 100% sure, but this is the kit they mount on the 2012-2014 bikes
Gesendet von iPad mit Tapatalk
Which kit?
From Athena
https://www.maciag-offroad.com/athen...-sid19482.html Here the pictures, left YZ and right GasGas The YZ cylinder is about 92mm high and the GasGas 94mm Gesendet von iPhone mit Tapatalk
Thank you for the detailed photos! Looks like the cylinder mounting studs are bigger on the YZ but we could use washers with flange head bolts.
gasgas ec 125 cylinder | eranmu | Enduro Engine - 2 stroke | 8 | 08-25-2016 05:17 PM |
GasGas 125 Halley Cylinder | Vladko | Enduro Engine - 2 stroke | 0 | 05-17-2016 03:09 PM |
Gasgas ec300 cylinder/barrel | Ec300stav | "Wanted to Buy" & "Want To Trade" | 3 | 10-08-2015 03:40 PM |
Who is the OEM mfg for GasGas Pistons? Plus S3 Cylinder upgrade? | Moto7man | General Discussions & Announcements | 6 | 04-26-2014 09:49 AM |
