Old 07-26-2020, 12:18 PM
pigpen966 pigpen966 is offline
Default Timing gap on flywheel
Hey guys, I have a 2018 GP 300 with the EE51100CT-CRB-1 CDI. Bike has run great for 210 hours. Started having no spark issues. Came down to bad CDI, got a EE51100CT-CLJ-1 CDI and it fixed no spark but timing is off. After some research they use two different flywheels. CRB-1 uses a 63 degree and the CLJ-1 uses the 30 degree. Anybody have both they can measure the gap for me?
TIA
Dick Carnes
"If ya run, you'll only die tired"
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
2006 DE 300 (buddy has it)
Old 07-26-2020, 09:35 PM
The gap is non adjustable.
Old 07-27-2020, 04:35 AM
The flywheel can be modified. It's the actual cutout in the flywheel itself. I can't recall where I saw the pics but think it was on Thumpertalk. The Aussie distrubuters were doing cdi updates and mods for owners. Mine is still the old one.
Old 07-27-2020, 06:32 AM
This is the picture of the two. I checked the parts list and there is different numbers for the 18 versus 19.
Would love not to modify it but the CRB-1 CDI is unobtainable I reckon.
Dick Carnes
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
Old 07-27-2020, 07:38 PM
Just to confuse you more.. Mine is a CLK on a 2018 EC250. Haven't physically inspected the flywheel cut out.
But in saying that. The CDIs are the same. It's the mapping on them that differs. Might be a dealer somewhere that can reflash the new one to your old 2018 setting vs modifying flywheel. Or can you source a 2019 flywheel?
Old 07-28-2020, 06:05 AM
I've reached out to a couple dealers in the US if they can reflash the CDI to the old map. This is what I'd prefer because the bike runs perfect with the original mapping. Still waiting to hear back from them. Then my next issue is getting it to them. With everything shut down there is NO mail going out of Costa Rica. I can still get stuff here thru a drop shipper but I'd have to find somebody to hand carry it to the states. Probably be at least a 2 month process. I guess that's the price you pay for riding a gasser in paradise!!
Dick Carnes
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
Old 09-02-2020, 01:45 AM
Duster Duster is offline
Hi, i changed to new flywheel due to bad spark with e-start, it run odewise perfect, i changed flywheel and gasgas dealership reprogrammed my cdi. No bad behavior came with it, only starts better. If u can do it somehow, it is worth it.
Old 09-05-2020, 07:10 PM
farmerj's Avatar
farmerj farmerj is online now
Duster, do you know what the difference was in the new flywheel, and why it made your bike start better?
I have the 30mm cutout, and the dealer re-programmed the CDI but didn't change the flywheel - and I'm wondering if that's why it doesn't start consistently (that is, when it turns over - but that's another problem!)
Jeff
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
Old 11-18-2020, 02:16 AM
Difference is ignition coil charging/loading time. With newer flywheel and new software, it gives good spark at lower rpm. I had also problem, that starter gives reasonable rpms to engine, but no starting and that was due to no spark or intermittent spark at e-start rpm's. The gap was approx double the size it was before.
2019 models flywheel and sofware also work and the flywheels are same.
Old 11-19-2020, 07:28 PM
farmerj's Avatar
I can have the flywheel machined to remove material and create the larger gap.
My question is - doesn't a flywheel need to be balanced? Asked another way, if I remove material by making the existing cutout wider, won't it cause the fw to be out of balance?
And does it matter which side of the cutout (or gap) the excess material is removed from?
Thanks,
Jeff
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
2k3 timing PEB Enduro Electrical & Wiring 2 06-26-2016 01:48 PM
Cam timing 450 FSE Just James Enduro Engine 4 stroke (including EFI & Exhaust) 6 07-18-2013 11:14 AM
PV timing? Fred1956 Enduro Engine - 2 stroke 3 04-14-2011 11:40 AM
Timing a 450? iancp5 Enduro Engine 4 stroke (including EFI & Exhaust) 4 05-28-2010 10:17 AM
For all who know Timing?? nwcycle General Discussions & Announcements 0 03-21-2009 11:25 AM
