Go Back   Rieju & GasGas Legacy Riders Club Forum > Community Forums > United Kingdom
Old 10-12-2014, 05:50 AM
richgilb richgilb is offline
Default any service people in yorkshire?
Looking for someone that knows the bikes inside out and does not charge vat, so that rules just about every dealer in the country out.
I want to get the jetting sorted, can anyone near me do this?
2003 EC200, 2013 Husky TE310, England
Old 10-12-2014, 01:19 PM
jilljoy jilljoy is offline
where abouts are you?there is a guy from crook county durham knows all gas's inside out and cheap as chips
GG ec 250 1998
v strom 1000 2008
Old 10-12-2014, 01:52 PM
savage sausage's Avatar
savage sausage savage sausage is offline
why pay a dealer when you can do it yourself?? part of owning a 2 stroke is learning how the carb/jetting works.
whats in it now (pilot / main / neeedle)
and whats the problem?
Old 10-13-2014, 12:41 PM
the local gas gas mechanic is listed on the gas gas approved dealer on their website in the trials section but does all bikes called alspan or al the spanner.he is really good for us guys that cannot do stuff ourselves
GG ec 250 1998
v strom 1000 2008
Old 10-21-2014, 02:05 PM
Thanks for these replies, guys. Sorry for the delay. Been spanking the bike on the Isle Of Man. See pic of my bike admiring the view during a piss break.
I am in Hull.
My bike uses double the amount of fuel a 2012 ktm 200 uses and 1.5 times the amount of a 2004 ktm 200.
It splutters in the low revs, at tickover it usually stalls but sometimes revs high. It starts very well but needs a handful of throttle.
I put a 250/300 gnarly on, in the hope it would help without needing jetting but the problems are still there and now I just seem to have lost top end with no bottom end worth having for the sacrifice.
I don't really know whether to start the jetting with the standard pipe or the gnarly, I thought I read somewhere that gnarly pipes don't need jetting. I can't really believe this but if true I could start with the gnarly on.
I am up for taking the carbs off and having a go. But after that, if it does not improve significantly, I would gladly take it to this guy in Durham. I work up there once a week anyway and have a trailer.
Old 10-23-2014, 11:29 AM
I am in Hull.
if you dropped it off in the morning it would probs be ready by teatime
GG ec 250 1998
v strom 1000 2008
Old 10-24-2014, 05:02 AM
Caravan Monster's Avatar
The symptoms described sound like the problem common to the EC 200 / 250 / 300. It's covered in the 2 stroke engine and jetting sections in this forum. You have to start with the engine, get the squish to something like 1.2mm either with thinner base gasket or skim the head. Then give it a new set of piston rings. After checking the piston, reeds, con rod bearings, mains and seals, powervalve tension et c. are ok (it is an 11 year old dirt bike), then start on experimenting with jetting. It's almost certainly not as simple as changing one thing.
My EC200 gets nearly 80 miles to a tankfull greenlaning on 13 / 48 gearing and runs fine (has Gnarly pipe, iirc)
It's a bit of work to do all this, but worth it. If you don't have the inclination to do this work on the bike, take it to someone reputable, they will almost certainly be familiar with the squish issue and a professional mechanic should get the work done fast.
'00 Montesa Cota 315R
'13 Husaberg TE 300
Old 10-24-2014, 02:34 PM
I have done some engine work with a gas gas dealer. New piston and top bearings, and I asked him to put on a thinner base gasket. He also checked the power valve and said it was good. He reckons the bike has done virtually no miles. Anyway, I have since cleaned the filter and will repack the silencer.
The guy in Durham suggested I got in touch with gas gas in Buxton, as he was more into trials bikes.
Taking the carb off tomorrow to have a look inside.
Old 10-26-2014, 05:20 AM
have a look in the carb and see what you are running ie needle slide, pj mj a/s position and im sure some will be able to point you in the right direction
its not that hard once you get the nack
03 ec300
honda cr500 94
Old 02-08-2015, 01:02 PM
Watty Watty is offline
There is a guy in Darlington ive forgotten his name but he used to and possible still does spanner for the gas gas riders on the scott trial , he is a wizz with gasser trials bikes and the same with enduro bikes , he used to work for Whites in darlington but has since set up his own business called 2 wheels only also based in Darlington , the man is a magician when it comes to jetting etc
Yorkshire rubber Jonny Pictures & Videos 15 09-24-2014 04:16 PM
calling all gasgas owners in yorkshire jjbaker1 United Kingdom 7 09-17-2014 03:05 PM
What do the people "in the know" think? bukwheat Enduro Suspension 9 10-09-2011 01:03 AM
people viewing UK forum stay_upright Suggestion Box 1 05-20-2008 06:54 PM
Lets keep the time Keeper going people! REVERUP GasGas Member Polls 17 02-06-2008 09:15 AM
