Old 03-20-2011, 10:52 PM
mudwasp's Avatar
mudwasp mudwasp is offline
Default trail tech vapor for 2011 ec 300
I did a quick search on this and didn't see that anyone had posted about it yet.If they have-sorry!
I just got my new 2011 ec 3300 e start! what a fantastic bike! However, i like to plate my bikes to thwart the national forest devils who think that by breaking up the trails with county road access in between, they will have fewer users of the off road trail system.Part of the process is making the bike street legal for the state patrol inspection- I needed a speedo ( thanks Gas Gas for leaving it off).
I bought the trail tech vapor speedo /tach-model 752-102 listed as a KTM model. It is absolutly plug and play- no mods of any kind( except cutting the radiator hose to put the engine temp sensor in). I could not believe how easy it was to intall!!! OK -THANKS GAS GAS, they left all the wires and connectors where they should be! I guess leaving the speedo off was one of the concessions they had to make to getting these fantastic bikes into the USA.But they made it easy for those of us who want one.
"No one expects the spanish inquisition"
2011 GG xc300
GG TXT 321 trials
Guzzi V7
Old 03-21-2011, 12:55 AM
gasgasnz gasgasnz is offline
take it you mounted it were the key is, were did you remount that or have you removed it now?
Old 03-21-2011, 04:23 PM
mudwasp's Avatar
I like my key!
I took the ignition mount off, took the ignition out of it, hammered flat the small lip that fits under the top clamp to hold it in position, and then mounted it on a diagonal so that i can reach the ignition. I took pix but am having a bit of trouble downloading them to my computer right now(usb problem i suspect).
2011 GG xc300
GG TXT 321 trials
Guzzi V7
Old 03-21-2011, 07:45 PM
mrkartoom's Avatar
mrkartoom mrkartoom is offline
I just ordered one of the Gas Gas Red Vapors from GoFaster via my dealer. I recently found out they are selling them as a kit, which comes with the mounting bracket and the speedo cable to the front wheel. Not a bad deal for $164 list. They are due to arrive sometime in April.
2011 Gas Gas EC300 38mm, 2008 Husky TE610, 2003 Beta Rev3 250
Old 03-22-2011, 09:28 AM
mudwasp's Avatar
I'm sure you will be happy with it- Being a geek i like having all that info available .I think it's funny that the instructions tell you to make sure you pay attention to the road!
2011 GG xc300
GG TXT 321 trials
Guzzi V7
Old 03-31-2011, 09:41 PM
mudwasp's Avatar
A footnote:
i took the bike out for a ride-the vapor works very nicely, however i guess i didn't get the bolt holding the mount to the bar clamp tight enough and it vibrated out.So my spouse found a bolt and nut to replace and put it back together with the addition of some blue lock-tite which got on the mount to the back of the Vapor DON'T DO THIS!! The lock-tite will degrade the plastic and the mount will break off! The folks at Trail Tech were very understanding about the situation and sent us a new mount- we have used their products on many bikes and are happy as usual.
2011 GG xc300
GG TXT 321 trials
Guzzi V7
Old 04-01-2011, 11:49 AM
06EC300 06EC300 is offline
Just put a vapour on my 06EC300......super easy
Old 04-01-2011, 02:59 PM
eff's Avatar
eff eff is offline
I recommend getting something like this to protect it and hold it better than the flimsy plastic mounts.
http://www.trailtech.net/022-SO.html
or http://www.trailtech.net/022-OEB.html
2004 GasGas DE250
Old 04-04-2011, 09:05 AM
mudwasp's Avatar
Thanks- i have had the trail tech billet mounts on all of my previous bikes- I have not gotten one for the new bike yet because of the ignition placement- I moved the ignition slightly but due to the short wires on the computer and ignition i'm trying to figure out if the billet mount /guard will make it impossible to turn the key.I've been designing an aluminum mount which i can make myself-or it would probably be simpler to just cut a solder wires and use the vapor mount
2011 GG xc300
GG TXT 321 trials
Guzzi V7
Old 05-18-2012, 09:56 PM
erniebearskin erniebearskin is offline
Hi guys, just installed Vapour on 2011 EC300 and I get no speedo reading. Everything seems to be installed corretly. Magnet is installed in rotor, passing directly in front of sensor threaded into caliper, which is plugged into computer. Im stumped.
Bryan
2013 Husaberg TE250 - Current
2011 GasGas EC300 - OLD STEED
2011 Husaberg FE390 - OLD STEED
2010 Yamaha WR250F - OLD STEED
#53B
I dream of a better tomorrow, where Chickens can cross the road, and not be questioned about their intentions.
Trail Tech - Voyager HydroDog General Discussions & Announcements 13 11-08-2010 01:29 PM
Trail tech troubles skid jackson General Discussions & Announcements 8 06-02-2010 07:15 PM
Trail Tech X bars sammyj18 Enduro Chassis & Body 11 05-06-2010 09:39 AM
Trail tech endurance FULLBURNER Enduro Electrical & Wiring 0 05-01-2009 06:48 AM
Trail Tech Vapor DAVe3283 Enduro Product Reviews 6 03-07-2007 06:33 PM
