Engine difference?
Does any one know what differences there are between the 1998 EC250
And the later models 1999 onwards. Also do any parts crossover?? thanks Darren |
I think everything but pipes from 07 and on will not work. I think the piston up to 2003 or 2004 will also work.
The '98 cases are a little bit different, the swingarm hole is larger in the '98, and the motor mount holes in the front and bottom are smaller, and i think that the crankcase area is smaller so you cant put a newer cylinder on it(i think) been so long since i had it apart, but i think that is what it was, i know that the cylinder and head are different for sure, side covers are the same, and clutch stuff is too. Trans will swap out with newer stuff.
99 EC 300 |
Just curious but I noticed the dreaded KTM stamped on the rad scoops does any one know what parts could or would cross over from other bikes??
2k-2 2k-3 ... difference? | swazi_matt | Enduro Electrical & Wiring | 4 | 10-20-2010 04:52 AM |
Difference between the 2010 models? | usedtobefast | General Discussions & Announcements | 9 | 12-27-2009 07:58 AM |
difference between ec250 and ec250 race? | Dirt Addict | General Discussions & Announcements | 2 | 10-24-2009 02:56 PM |
Compression distance difference on pistons | Adrian | Enduro Engine - 2 stroke | 6 | 05-17-2007 06:50 PM |
