Old 07-06-2020, 06:15 AM
Cox76y Cox76y is online now
Default Mousse blow out
Just wondering if anyone has had a mousse fail on them. I was on my 3rd ride with a mousse over the weekend when the mousse tore in half and fell out of the tyre. I was very surprised as I thought I would get a lot more use out of it.
Old 07-06-2020, 08:44 AM
masterbill masterbill is offline
No nothing like that with mouses.
The only problem I have had is with a mouse that had shrunk on the front and the front end would fall away on certain corners.
The mouse was well used and old.
Old 07-06-2020, 11:52 AM
I've been seeing that happen a lot lately.
I haven't had any issues, yet.
Old 07-06-2020, 04:02 PM
was your third ride close to your first or long periods between rides? I know mousses need to be lubed regularly (every 6 month or so) and also don't like high speeds (remember the first dakar in South america?)
The bike should also be stored on a stand so the mousse doesn't develop a flat spot
all reasons to use tubliss ;-)
Old 07-07-2020, 06:11 AM
Probably about 5 months since I got it installed. The bike had been up on a stand for some of that time. Think I'll go back to tubeliss now. Pity about my golden tyre. I might try to throw a tube in it..
Old 07-07-2020, 01:39 PM
ScottyR ScottyR is offline
Junior Member
What brand? I have had bad luck with the Nitromousse brand.
Old 07-07-2020, 03:38 PM
Nitro Mousse are junk.
I found out that you pretty much have to run bibs mousses in Michelin tires.
Old 07-07-2020, 03:54 PM
I think there was an issue with the first gen of nitro mousse with them shrinking, not sure if there was a recall, but have heard there is a new version
I know tubliss says to use a new tyre, but if your old tyre is still in good condition i would try it anyway, maybe add a bottle of slime in with it to seal any deformities from the rim lock
Old 07-08-2020, 07:40 AM
Not sure what brand of mousse it was and I don't know if I'll get a good seal from the tyre now. We were able to get the tyre back over the rim without using levers. I'll have a better look when I get a chance.
Old 07-08-2020, 12:00 PM
If you were able to get the tyre back on the rim without levers, whoever installed it has broken the bead and that?s what caused the mousse to come out the side.
Seen it before a fair few times.
Inventory Blow Out Sewerat General Discussions & Announcements 4 12-30-2019 06:10 PM
Gas gas aftermarket parts blow out sale County Cycle Parts 10 06-17-2015 07:21 PM
Blow by chchnick Enduro Engine - 2 stroke 16 05-07-2015 02:42 AM
Les Blow Trial- Vancouver Island South roughside Canada 0 02-02-2011 10:09 PM
That's a blow for you yanks TooFastTim General Discussions & Announcements 2 06-24-2008 08:20 PM
