Old 06-01-2019, 11:23 AM
GASGASCWB GASGASCWB is offline
Default 2019 battery specs!!!
Hi guys.
Could anyone report the specifications (CCA, AMP...) of the 2019 lithium batteries?
The brand too?
Thanks so much.
Old 06-20-2019, 11:04 AM
Biff's Avatar
Biff Biff is offline
not sure if this helps, but on my 2013 i've just fitted dedicated earth wire, and a
BCTX7L-FP-S
12V - 160CCA
www.bclithiumbatteries.com
Old 06-21-2019, 12:06 PM
BCTX7L-FP-S
12V - 160CCA
Ok.
Thanks for your answer!
I bought this:
ALIANT YLP14:
http://www.go-aliant.com/lithium/ind...le-battery-ylp
Stupid power!
But if you do not use everyday or do not disconnected from the bike, have the same problem commom all the lithium batteries.
The lithium batteries is not mad for only weekend uses.
Battery tender help this problem.
Old 06-21-2019, 02:04 PM
Lithium batteries are fine for non frequent use as long as there is no drain on the battery. Google parasitic drain and do some tests on your bike. Mine has sat for a couple of months with no charge and fires straight up on the button on the still stock battery.
Old 06-21-2019, 08:18 PM
Sorry but I totally disagree!
See what the manufacturers say to non-frequent use!
If you unplugged her from her bike, perfect.
If you do not disconnect, the battery is naturally discharged.
If you do not like to completely disconnect it from your motorcycle, a battery tender is imperative for the lithium battery to last for some reasonable time!
Old 06-22-2019, 08:02 PM
That?s fine for you to disagree. I?ll just keep continuing to run the three of my vehicles on lithium?s with no charge and enjoy the weight savings.
Reread my post. There needs to be no parasitic drain on the battery for you to be able to leave them connected. If you fail to do these tests if you have a problem then the bike will drain any battery fitted.
Old 06-23-2019, 07:26 AM
shawbagga's Avatar
What could be draining an XC model as no lights/speedo etc?
'18 Gasgas XC250
Old 06-23-2019, 04:36 PM
There is no need for an "accessory" installed on the motorcycle for the natural unloading of the battery.
The fact that the battery is connected to a motorcycle and that it is on ikcstand, causes it to discharge naturally.
A rubber rug would already help.
But the ideal is to disconnect the positive pole.
Old 06-23-2019, 11:17 PM
Faulty regulator can have a drain. They can be a pain to diagnose sometimes too. People often keep throwing batteries in bikes with other undiagnosed issues. I?ve got a 6 year old lithium in my Mt-09 that a guy said was faulty as it kept discharging. I?d been using it as a camping battery to run some spotlights and what not.
Been in my road bike for a couple of months now again with no charger and no issues.
Old 06-24-2019, 02:57 PM
This pic sums up what I mean:
Bike won't run without battery and won't charge battery memphis2857 Enduro Electrical & Wiring 3 04-28-2017 09:02 PM
'06 EC 300 bar specs brider Enduro Chassis & Body 1 07-30-2014 01:34 AM
torque specs kstreet Enduro Engine - 2 stroke 1 01-28-2011 07:05 PM
05 De 300 Specs VORMAN Enduro Electrical & Wiring 9 11-14-2010 06:36 PM
ring gap specs jostby Enduro Engine - 2 stroke 9 10-27-2008 06:18 PM
