Old 06-22-2019, 02:32 PM
adriano.ro adriano.ro is offline
Default Main jet question ( N3CH)
Recently I returned from ktm to GG
So,my ec 300 2010 is in very good shape.
My carb specs are:
Carb 38 asll
42p N3CH#3 172 main.
I didn't ride the bike yet ,only around the house. bike start ok,idle ok.
Revs clean but seams to stop reving 100%. 85% maybe .
Is 172 main ok for this needle?
Old 06-22-2019, 06:34 PM
Nocams Nocams is offline
175 would be my choice.
250m-1200m elevation is the altitude I ride.
This combination worked well on both my 2010 and 2015 ec300’s with both bikes squish measuring up at a loose 2.1mm.
2011 TXT300R
2018 EC300GP
Old 06-22-2019, 09:59 PM
Just try it a size smaller and see if it is better or worse. Your bike with your oil ratio with your local gas and altitude etc. . .
Mine needed a 170 to rev out cleanly.
Old 06-22-2019, 11:02 PM
98 RON gas, 300-1200m alt. , temp around 25C, oil ratio 50:1.
I don't know if is a good thing or a bad thing, but when I bought the bike start soooo easy,I mean u can kick very easy to start it,was Ipone oil premix. So after I put in BELRAY SI7 ,compression was higher!
Old 06-23-2019, 07:44 AM
I'd try the 170 main jet first...
Old 06-23-2019, 12:22 PM
Update.
42 N3CH#3 170 and 172 is lean on pilot.
42 N3CJ is lean in every clip position.
42 N8RJ#3 170 this needle is got the best top end power
42p NECW#3 170 is the best what I can do for now.
But I don't like how the bike work,I don't know if the jetting is the only issue but this bike has no power on midle throttle.
I also tried NECW#4 ,more power but to rich on needle. Is strqnge how it feels,is kind of flet power,and the engine sound ia more pronounced in air box area.
Is like power valve issue but is all good there.
Very weak after 3 years of ktm..
I like so much the bike,but the power is weak, is like 250..
Other mods, ignition timming to be more snappy, I took off reed valve spacer, 13-50 gear ratio,0.35mm cylinder base gasket,1.8mm squish.
Old 06-23-2019, 11:11 PM
Sort your squish out. Then start again with the jetting.
Old 06-24-2019, 05:25 AM
Rings are ok,power valve works ok. I want to check the crank seals, spark plug looks ok,no oil on it,but u never knows.
LHS seal is a little bit wet.I'll change it for peace of mind.
Old 06-24-2019, 03:02 PM
Update.
I've changed the cylinder base gasket. From 0.35 to 0.45 and I mill the cyl. head 0.50mm only from o-ring part.
I have also checked the power valve resistance,I loss of a bit.
I've moved bottom piston ring up,was better than top one.
THIS THING RIPS!!!!!
HOLLY F@#$
Just a little bit of hesitation from 0.15%-0.30% off throttle.
Main Jet question 95jersey Enduro Intake/Carburetion - 2 stroke 5 07-09-2015 10:11 PM
NEDW vs. N3CH vs. N3EW memphis2857 Enduro Intake/Carburetion - 2 stroke 11 05-15-2015 10:46 PM
difference between N3CH and NECH? ggmaniac Enduro Intake/Carburetion - 2 stroke 8 05-05-2013 09:36 PM
N3EH/N3CH - Plug readings Jakobi Enduro Intake/Carburetion - 2 stroke 17 07-20-2011 12:20 AM
Main Bearing question wrench Enduro Engine - 2 stroke 12 05-18-2011 09:39 PM
