Old 02-26-2011, 01:55 AM
iancp5's Avatar
iancp5 iancp5 is offline
Originally Posted by Crankin04 View Post
Can you post pics of yours? It might help me find mine...
Thanks!
Sure. I think. My camera's battery is flat. I'll try and get it sorted in a day or two. Have put it on charge.
Old 02-26-2011, 08:55 AM
iancp5's Avatar
Default Image 1
Old 02-26-2011, 08:56 AM
iancp5's Avatar
Default Image 2
Old 02-26-2011, 08:57 AM
iancp5's Avatar
Default Image 3
Old 02-28-2011, 04:55 PM
Crankin04 Crankin04 is offline
Originally Posted by iancp5 View Post
Awesome. I actually do have that same screw on mine for air bleed. So should I loosen it turning left or tighten turning right? How far? Should I just go all the way one way then try starting every rotation back until it starts?
Lol, sorry I am still a newbie with the Gas Gas 4t's :P. Thanks again for Pics!
Crankin04
04' GG FSE 450
Live Easy, Ride Hard!
Old 03-01-2011, 04:08 PM
iancp5's Avatar
I just adjust it to give the fastest idle, that seems to also provide the best starting.
Old 03-01-2011, 04:17 PM
Yeah gotcha. So which way looking straight at it, did you turn the air bleed screw to get faster idle?
Thanks,
Crankin04
04' GG FSE 450
Old 03-02-2011, 02:16 PM
iancp5's Avatar
Thanks,
Crankin04
I have no idea now! It would depend on the specific bike anyway. It'll change with a big temp difference as well so you may find you need to adjust between winter and summer. Just try it both ways until you get the fastest, most even idle. There'll be a range of about 1/4 - 1/2 a turn where it is good but doesn't change much. Set it in the middle of that.
Old 03-02-2011, 02:50 PM
My screw was like, all the way in. Once I turned it left to loosen out a bit, I was FINALLY able to start it and it idled fairly well! I was able to turn off and start up again pretty easy too. The only thing I noticed was my bike would start to die down in idle speed, before it would just shut off. It's like once the engine is warmed up, the idle speed drops until the bike kicks off and could be anywhere from 30 seconds to 3 minutes.
Do you think it has something to do with air bleed screw once the bike is warmed up and hot? Maybe some other issue causing that?
Thanks for all your help!
Crankin04
04' GG FSE 450
Spark plug gasgas125sm08 Enduro Engine - 2 stroke 0 03-08-2010 09:42 AM
EC 250 Spark plug Grampy Enduro Engine - 2 stroke 11 12-16-2008 12:24 AM
01 ec300 spark plug.... jhendr3702 Enduro Electrical & Wiring 1 07-02-2008 07:53 PM
Spark plug gap???? Bandit9 Enduro Engine - 2 stroke 1 08-29-2007 05:26 PM
