"Wanted to Buy" & "Want To Trade" Bikes or Parts |
WTB 48mm Forks 2011 EC300 Needed Now
Hey everyone!! I'm new here and was hoping you guys could extend a hand to help. The capture nut on my Sachs forks (with Ohlins inserts) came loose and the whole dampening rod came out, went back in and will not come back out! The builder I took it too said either way it's toast (stripped threads, etc) so to get back out riding I need some forks! Any info leads etc would be greatly appreciated! You can reach me at 9702372028. I'm really hoping someone here has a set or knows of someone that does! Thanks guys and I look forward to being a member (been creeping around for a while now).
Thanks
"When I'm riding, I'm living. Everything else is just waiting." |
I have a set of sachs but shipping is going to be a killer. Lots of threads on replacing front end with yz forks, that's probably going to be your easiest route
Fotks
I have some older 45 zokes and a newer set of 48 zokes and I live in Colorado the 45s are cheap but not the 48s there off a 13 you will need a new lower clamp for the 48s also
I also have a set of 48mm Marz off a 12 and a triple to go with. Located in colorado.
Please give me a ring or text at 9702372028. I'm in Colorado too if one of you guys could help me out VxZeroKnots or frankinberg!
Tags |
48mm ohlins marzochi |
2011 250 Six Days w/ 48mm Marzocchi Forks | roverhybrids | Used Bikes | 5 | 04-24-2015 02:22 PM |
Clear wiring diagram needed 2011 ec300 | gasgasmick | Enduro Electrical & Wiring | 5 | 12-30-2013 12:58 AM |
WTB: 48mm forks and triple clamps to fit 2010/2011 | bkwdc | "Wanted to Buy" & "Want To Trade" | 3 | 10-22-2013 05:08 PM |
48mm Forks | Scramble Champ | "Wanted to Buy" & "Want To Trade" | 1 | 02-28-2013 07:09 AM |
48mm MRZ forks tool needed | Synergy-Seals | Enduro Suspension | 1 | 07-17-2012 12:41 PM |
