Old 12-29-2014, 04:42 AM
husley's Avatar
husley husley is offline
Bronze Level Site Supporter
So it sounds like a "yes".
Thanks to all.
J
2015 KTM 450 XCW
2014 350 XCF Wife's
2009 200 ec. Loving it
2007 Beta Rev 3 270
2007 KTM 200 XC Wife's
Public Lands belong to the Public
Old 12-29-2014, 09:33 AM
SailDestin SailDestin is offline
My riding buddy has an 08 ktm 200xc-w and i ride an 02 gas gas xc200 and i wouldn't trade him for the world (unless i could sell the ktm after the trade and buy another gas gas . We ride mostly tight single track but some wide open flowy stuff too. Although his bike is 4 pounds lighter you would never be able to tell. Something about where the gas gas carries its weight. He has been able to almost stay with me before on a yz125. On his 200 i think hes slower(although since he got the 200 i have also gone Tubliss with Metzeler mc4s which if you havent gone tubliss you dont know what your missing!). Motor felt no more powerful to me, in fact i prefer the was the gas gas revs out. I got the gas gas on accident but have fallen in love and just bought a 300 of the same year. Oh and my xc is street titled so i can ride on the 474,000 acres of Air Force Reservation that surrounds me. I love gas gas!!
Old 12-29-2014, 05:46 PM
If you do not opt for the head mod a cheap solution is to use a thinner cylinder base gasket which will advance the port timing and bump compression. Advancing the timing will in enhance bottom end to.
Unless you ride it wide open all the time, a 38mm carb is too large for a small cc enduro engine. I put a 35mm carb on a EC125 and a MC125 in place of the 38mm that came stock. With the smaller carbs they jet easier and run much cleaner/better at low rpm.
Old 12-30-2014, 02:37 AM
(F5) (F5) is online now
My 02 had 2 gaskets std I removed one which reduces the open duration making the ports open later so I wouldn't call that advanced. But the head mod is still required. If you get the squish close enough so it is working, the comm will be too high so it does need machining of the dome as well as a healthy skim.
Old 12-30-2014, 01:26 PM
I found this. http://polariswatercraft.com.au/basi...roketuning.htm In general, if a tuner wants to adjust the engine's power band for more low to mid range he would do the following things. Turn down the cylinder base on a lathe to increase the effective stroke (distance from TDC to exhaust port opening). This also retards the exhaust port timing and shortens the duration and increases the compression ratio.....
Old 12-30-2014, 02:06 PM
gasser's Avatar
gasser gasser is offline
Several good suggestions here already but I will add one that always works - gear lower. If you don't ride faster than 50mph I would suggest 12/50 gearing on a 200. 13/54 would be close to 12/50 but would take a longer than stock chain. Yes a 12 tooth cs will wear a tad bit faster but the wear difference is little enough to be a non-factor. Chain slider will wear a lot faster (with a 12 cs) if you run a loose chain.
Old 12-30-2014, 09:06 PM
Smartest thing said yet Gasser.
Z, yes retard is closer to correct. But they aren't really using a good description of what happens in a running engine. Not that it matters, and I'm starting to sound like a dick.
Old 12-30-2014, 10:09 PM
husley's Avatar
Nope, I rarely get over 50 mph.....almost never. Rarely over 40mph. I like Single Track and I am a low/mid-range rpm guy with a trials background. I'm keeping my 10' 300 and making it my Dual Sport, the 200 will be my 'trail bike' . Last year on my 300 I lowered the gearing, added a PV cover and adjusted the squish, this took away from the top-end but I was just fine with that as it turned the bike into a tractor
12/50, okay thanks for the tip!
It appears I will be buying a 09' 200 with less than 30 hrs on it. It has the stock pipe.
Guessing these will be my mods for more low-end (if needed) in approximate order:
Ensure Jetting is correct/best for low-end
PV cover. -put one on my 10' 300 and liked what it did
Gearing 12/50 I guess. Maybe even lower?
Reed or Pipe spacer ....maybe ?
Flywheel Weight
Squish
Does the 09' have the rain/sunshine switch?
Happy New Year!
J
2015 KTM 450 XCW
2014 350 XCF Wife's
2007 Beta Rev 3 270
Old 12-31-2014, 02:25 AM
paulos paulos is offline
Also, make sure the power valve is correctly adjusted. I'd actually do this and check the squish measurement/have the head machined, before you start doing anything else.
2011 Gasgas EC200, 1966 BSA 350 scrambles, 1972 Montesa cota 247
...and maybe check piston and ring for wear
does anyone make a big bore kit? seamonster Enduro Engine - 2 stroke 9 01-21-2012 09:05 PM
The Pro's Make It Look So Easy Rick Pictures & Videos 1 12-04-2011 10:49 PM
How to make gaskets Rabbitist Enduro Engine - 2 stroke 5 09-17-2011 07:46 PM
Do they make FMF SST gasser250sm Enduro Engine - 2 stroke 1 12-26-2008 10:16 AM
If we make it... would you buy it? Steve@Motowest GasGas Member Polls 12 07-09-2008 01:15 AM
