Right side out case removal problem - Help!
I'm dealing with the broken water pump impeller issue. Mark at Gofasters is sending the parts (Thanks Mark). I want to remove the whole WP assembly (WP housing and the portion of the case that surrounds the clutch) - I'll call it the clutch/WP housing portion of the engine case.
I've removed all bolts from WP cover and the clutch/WP housing. I can pull the rear portion of the housing from the center case but the front of the housing is resisting removal. I small gap has opened but I cannot completely remove it. I'm guessing that there is some corrosion around a index pin and I am resisting the urge to pry it off. I have not missed removing any bolts like I usually find when I have this kind of problem Am I missing anything? Rick 2012 GG 300 |
Pics??? I think I almost kinda understand what your explaining. I've got the same bike and mine is apart now soooo.... Pics?
2012 gas gas ec 300 WHOA BARB!!!!! 2003 ktm 300exc....for sale 2003 kx 250 woods out..gone 2002 ktm 400exc.... bye bye 2005 yamaha wr 250f...too slow! 2001 ktm 300exc....lemon i think 2003 kx 250...wow but gone... 2008 dr 650..what was i thinking... 1987 yz 125..started it all.. |
once all the bolts are out should just pull off but push with your thumb on the kick start shaft so you dont pull that aswel easier just to leave it in place on the engine
I had the very same issue when I went to remove mine. There is a dowel right at the water pump. And that dowel was pretty rusty which was the reason mine was so hard to get off. I just kept working it back and forth and pried it off eventually.
Once off I cleaned the dowel up very well with emery cloth and then during installation I covered it with Motor Assembly Lube from Honda. Be patient it will come off.....
2012 - XC 300 Racing Seattle, WA |
Thanks StuJohnson...that is exactly where mine is hanging-up. I'll keep working it
Rubber mallet and some light tapping back and forward will help with the process.
I had similar issues, and took a piece of alum angle iron,drilled two holes corresponding with the water pump cover,and used the angle as leverage wiggling back and forth until free. it did take awhile as I was extra cautious.
The dowel was rusty as well. |
Coolant will become acidic if not changed every so often, or if non-distilled water was used, or if different types of antifreeze were mixed (either by adding a different type or by not flushing thoroughly, or by using one of the organic acid-based extended life coolants. |
Phil (New bike pending...) |
C'mon plain water really.... Go out to your bike and take a close look. The bolt hole goes THROUGH the case. I realize in AZ you don't get the rain amounts
as others. A little dab of silicone solved the problem. |
I bought a 2000 xc and keep finding problem after problem | 675AZ | Enduro Engine - 2 stroke | 12 | 02-15-2013 07:25 PM |
oil sheen on clutch side case, any thoughts? | nambo-trev | Enduro Engine - 2 stroke | 11 | 10-31-2012 07:58 PM |
2001 xc250 linkage removal problem. ..trapped bolt | 70455 | Enduro Suspension | 21 | 09-22-2012 11:34 AM |
