Old 07-27-2009, 03:07 AM
stay_upright's Avatar
stay_upright stay_upright is offline
Default Cylinder measurement results below so which size piston?
I've had my cylinder measured with a 3 prong gauge,
Top just below TDC for rings:
71.993
71.993 (tool rotated 180 degrees)
Above ports
71.991
71.994 (tool rotated 180 degrees)
Below Ports
71.998
71.992 (tool rotated 180 degrees)
Bottom of skirt
72.00
71.998 (tool rotated 180 degrees)
So basically then it's 71.99 to 72.00 depending on where it's measured.
So if some parts are at 72 and the piston needs 0.06 to 0.1mm clearance and I aimed for 0.06 clearance I would need a 71.93 piston though I think the smallest available is 71.94 in a vertex. (if the 71.94 refers to the max piston diameter?)
Does anyone know what size the weisco is?
Does this make sense?
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Old 07-28-2009, 12:43 AM
Ordered a Vertex A - smallest size.
'05 Gas Gas 300
'99 KTM 200
What "size" piston without removing barrel Eugene Enduro Engine - 2 stroke 20 01-04-2012 10:55 AM
piston rmoval/cylinder head thingymijig Enduro Engine - 2 stroke 2 03-01-2007 04:51 AM
