2014 300xc gear oil
What gear oil are you using or recommend.
Thanks |
I use belray gear saver in my 2010 300
Trans
I like ATF in my bikes but not with the rekluse I use the rotella they recommend
Otherwise I liked how the ATF worked with clutch and gearbox Stoby |
Amsoil 10-30 here. Seems to work well, no clutch noise.
Lately I have Used GRO. Earlier I Used Castrol MTX. Both with good results but some Rekluse clutch noise.
Anders "So you know, that you're over the hill when your mind makes a promise that your body can't fill" (Little Feat: Old Folks Boogie) 2015 EC200 Racing: TE bars, Rekluse Core Exp 3.0, 38mm Lectron & Ohlins S3 steering damper 2006 EC200: 2011 plastics, Rekluse Z-Start, revalved KYB forks & Scotts steering damper 1998 Bimota Supermono 1986 Duc Mille S2 1975 Guzzi sidecar hack 1961 Morini Corsaro 125 etc Last edited by Anders; 10-16-2015 at 06:05 AM. |
Good ol Shell Rotella T. Can but a gallon of it at Autozone for what one quart of "motorcycle" oil costs. I have been using it for years. Actually this is the oil Rekluse recommends for their clutches
Sent from my iPhone using Tapatalk |
Thanks for the responses I forgot to mention what wieght are you using.
Thanks |
Atf dexron vi is the best spec oil you can possibly get. GM (makers of the dexron specification) require it last 100,000miles in ordinary use and 50,000miles for heavy use.
Auto gearboxes in cars are very similar to bike gearboxes. I use the same stuff in my forks (its equiv 7.5w) and it retains viscosity better than any fork oil over seen at high temperature (viscosity index). I also use it in my clutch reservoir. One oil to rule them all! Enjoy http://www.ls1gto.com/forums/showthr...=1444944494388
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 Last edited by motopsycho87; 10-15-2015 at 04:30 PM. |
Motorex 10w30 in the 05 300 and the 11 250.
Motul Transoil 10w30 for me, i have filled with Castrol 10w30 once but i won't go back to it unless it's very urgent.
'14 EC300 |
Thread Tools | |
Display Modes | |
WTB 2014 e-start ring gear | dANbOT | "Wanted to Buy" & "Want To Trade" | 0 | 07-12-2015 08:36 AM |
2014 GasGas 300XC | Forestgrump | General Discussions & Announcements | 4 | 03-05-2015 04:58 PM |
Wanted!! Ec200 seat, radiators, switch gear, gear lever | Kendog | "Wanted to Buy" & "Want To Trade" | 2 | 10-12-2014 03:12 PM |
