Old 07-26-2012, 11:15 AM
Diggs345's Avatar
Diggs345 Diggs345 is offline
40 pilot
Cck 2 from top
Airscrew 2.5 out
175
Thats much better than the setting i had before , i did try the needle in the middle but it was bogging starting to bog again unless you rolled th throttle on real slow.
Old 08-09-2012, 01:20 PM
Diggs345's Avatar
Righty oh , I got a Suzuki needle thanks to gassergrant , it's a nedw ...
How does that compare to the nedj ?
Old 08-09-2012, 02:37 PM
Its one step richer from idle to 1/8th throttle.
Old 08-11-2012, 03:11 AM
Diggs345's Avatar
Thanks jake , i currently have n1ef , nedw, cek and cck with the cck in at the moment , i think my bike is running a bit hot with this needle as it there was coolent leaking from the overflow , but that may be to do with fitting the rekluse and trying to trials ride it , to my eyes the cek looks very lean but very progressive ,not sure about the cck as its in the bike at the moment , the nedw looks to be more linear than the n1ef , so im going to try the nedw for a bit today to see how that pans out, any thoughts on carb setup with that needle.
im off to wales in the morning so id like it to be right , any maintenance on the trail with a gas gas starts the ktm hyeenas with thier gas gas unreliability jokes
Old 08-11-2012, 04:25 AM
40 NEDW#3/2 175/172 main. Should have it zippin around no worries. Seeing as you have the 40 and 175 in there already I'd just start with clip 2 for a test ride. Move to clip 2 if it feels too rich. Then after your weekend decide if you want to drop the main.
Not sure on the root diameter of the CCK but if the bike idles high when you put the NEDW in don't freak out immediately thinking its lean. Simply try to back the idle down to a good level.
Old 08-11-2012, 04:29 AM
Diggs345's Avatar
Cheers jake your a star man as always , I'm just putting some more tungsten balls into the rekluse then I'll sort the carb , then out for a spin for an hour
Old 08-11-2012, 04:31 AM
Oops.. Start with clip 3.. Then move to 2..
Can you still get the slide out with the tank off? Or is it a remove the whole carb every time deal on the 2012s??
Old 08-11-2012, 05:10 AM
Diggs345's Avatar
Yeah tank off to get slide out , but I'm having to take carb off to change jets
Old 08-11-2012, 05:16 AM
Sweet. Guess thats a bonus then that you can have a play with the jets that are already in there. I dread having to turn the carb to access the jets through the plug. Bugger having to pull the whole thing every time!
Old 08-11-2012, 05:59 AM
Diggs345's Avatar
I suppose you could spin the carb ok if the slide was out , will have a go in a min
EC 300 Jetting Casey97 Canada 6 05-05-2011 11:52 PM
GG jetting Gasgasogeros Enduro Intake/Carburetion - 2 stroke 0 02-21-2011 06:39 AM
04 ec 300 Jetting lordfeyr Enduro Intake/Carburetion - 2 stroke 12 01-26-2010 03:16 AM
jetting macho comacho Enduro Intake/Carburetion - 2 stroke 21 03-10-2009 03:11 AM
02 ec 250 jetting help crem55 Enduro Intake/Carburetion - 2 stroke 9 07-12-2007 01:44 PM
