#11
I found a large opening from the airbox to the rear fender, think it is for wiring the rear light but is in a place that let's a lot of water in
My flap seems to have bent slightly open, I think I should flip it around so it seals
#12
on the WWW I hear. No experience aye!
Matt, No real issue with the flap not pushing up hard. Mine has a small gap at the front too. The way I see it is that if you submerge it the water pressure coupled with expected forward motion should be enough to keep it shut. My airbox always looks like its been caked in mud and water but never any past the filtero. |
#13
I suppose if a guy insured his bike and used a fire torch it would solve the problem....
03 EC300 The pig...04 XR650L 01 380sx |
#14
Mine has clogged and stuck open several times, and I have cleaned and flipped the flap/reed valve. A trick I used on the older pre '07 airboxes with the baffle in the bottom was to add a block of filter or skid plate foam to the well in the bottom. This prevented all the crud from comming up through the bottom, while allowing any splash water that made it into the aixbox to drain through. Worked well, and would probably work good on the new airbox too, keeping the little flap valve clean.
Water in the oil | Arrhe | Enduro Engine - 2 stroke | 0 | 06-25-2011 11:54 AM |
water in oil | gasit16 | Enduro Engine 4 stroke (including EFI & Exhaust) | 1 | 01-27-2011 10:58 PM |
Water in oil | Mad Mike | Enduro Engine - 2 stroke | 10 | 04-20-2010 12:26 AM |
water pump? | nhrider | Enduro Engine - 2 stroke | 17 | 12-21-2008 12:05 AM |
water crossing | mountain thumper | Riding Techniques & Training | 4 | 07-28-2008 12:58 AM |
