Old 01-20-2022, 02:56 PM
Niall-griffiths's Avatar
Niall-griffiths Niall-griffiths is offline
Default 2018 battery / wiring
Hi all have a 2018 gas gas ec300 guy I bought it off said under warranty few years ago it had a replacement starter motor ect from a 2019 model. The electric start rarely works so I took the seat up to find only a 50cca battery fitted. Can anyone tell me what battery?s fit I?ve seen some 200+cca ones can fit but don?t know what ones as no one left the model number.
also how do I know if the wiring upgrade from the battery and starter has been carried out by eye?
Old 01-21-2022, 12:25 PM
blitz11's Avatar
blitz11 blitz11 is offline
I have a 2021 TM 300 EN FI bike, and it comes with this battery:
BATTERIA ALIANT YLP09X 12V EQ. 8AH
You can get these in England pretty cheap:
https://www.roadraceperformanceshrop...attery-12v-8ah
It spins the TM over like crazy.
I am not sure if this had a battery management system built in (basically, a charge regulator), but you could call to find out more.
In the US, this battery costs $250 from TM. If this dies, i'd probably preplace it with a earth x: https://earthxbatteries.com/shop/etz5g.
This battery is about 1/2 the price of what TM charges.
My $0.02.
Old 01-21-2022, 04:55 PM
I have the AntiGravity in my '18.
I haven't charged the battery in 2 years. Works flawless.
Old 01-21-2022, 06:32 PM
blitz11's Avatar
Hmmmm - which antigravity?
Old 01-22-2022, 08:03 AM
What model one is this ??
Old 01-22-2022, 04:49 PM
AntiGravity
ATZ7-8. 240CCA.
Old 01-25-2022, 05:39 AM
Got a jump pack on the bike to find only 4v down the starter wire so will order a new relay as it just clicks and only passes 4v both 30a fused are ok.. Tried to remove the relay and touch the starter wire straight to battery it just sparks doesn?t turn the starter. Where is best going from here??
Old 01-25-2022, 05:41 AM
Just attached the jump back straight to starter and earth to starter bolt to find motor turns. What gauge wiring are people using and where abouts are they running the extra earth wire ?
Old 01-26-2022, 12:26 AM
I used some heavy gauge cable I had lying around but I ran the earth directly from the battery to the bolt that holds the starter on.
Old 01-30-2022, 12:40 PM
5valve 5valve is offline
In EU, '18 came fitted with li ion battery, skyrich, made in china. Brand can also be bought as original spare part for KTM.
'19 model came fitted with larger capacity skyrich, model HJTZ7S-FPZ - 240A.
If in doubt, replace wires with 10mm2.
Also replace bendix cover with rieju unit with bearings.
While at it, weld bendix and gear as per that video.
https://www.youtube.com/watch?v=CXXjFw9ghDE
If starter goes south, freely use KTM replica from aliexpress, reverse polarity.
Do all those mods, not just few. It is a best bet for longevity.
Always kick cold bike, and e start when hot. Manual says so too for a reason.
24V system, for my liking too much complication and not addressing primary issues, unless mods are carried out.
With all mods and correct battery, bike starts like crazy.
EC 300 2008
EC 300 2018 GP
tenere 700
Battery for 2018 Contact 250 ES DebS Trials Other... 5 08-25-2021 06:33 PM
2018 new battery andykr87 Enduro Electrical & Wiring 9 04-09-2020 06:39 AM
180 CCA battery on 2018 300? Wypipo Enduro Electrical & Wiring 9 10-16-2018 05:10 AM
2018 Gas Gas Battery tip Buddmatto Enduro Electrical & Wiring 0 09-07-2017 07:21 AM
Battery Wiring shang Enduro Electrical & Wiring 8 12-31-2015 10:23 AM
