Ec250 cylinder damage
Hello guys
We removed cylinder right now and it seems there is a damege on it. Could you look at the picture please. Ec250 2012 200hours with stock piston. Yes it is stock. |
200hrs is a lot to ask of a piston, but the cylinder does not look to bad.
Any other photos? what pre-mix are you using?
'12 XC 200 TTX Sold '15 XC 250E Sale pending |
200hrs on a 250 is pushing it. I pulled a top ring out at .9mm at 110hrs on mine.
As for the cylinder, such is the price you pay. By leaving the piston and rings go so long it allows the piston to rock in the cylinder a bit. I'm betting the piston has some decent wear on the skirts. In saying that, it also appears the clylinder hasn't been cleaned at all yet, so before you draw too many conclusions get a scotchbrite pad and some carb cleaner and give the cylinder a good deglazing. I'd then suggest measuring the ring end at several depths in the bore, or having a shop spec it up with a bore gauge. |
Hello,
50:1 premix we used but dont know what previous user used. More photo, |
Are those scratches you can catch your fingernail in? They look more like shiny spots from scuffing.
2011 EC250E |
Send it out to Powerseal USA, tell them to check and measure if its in speck they ship it back to you. If it needs to be re-plated you looking at about 200.
They do quality work and have a real good turn around time. |
It may also clean up with a diamond hone job for $25 to $30.
I agree. Visual is OK but if you can feel the scratches with your fingernail it's time to have the cylinder repaired.
We are at Turkey guys. Not possible to send it anywhere in US. This is my friends bike. I persuade him to change piston. Rings is not in good condition. Rings wearing are so much. Piston is full black I will try to send a few photos of piston and rings.
I can not feel any deep, when i use fingernail. Thanks. |
Air Filter damage | Buysomerice | Enduro Intake/Carburetion - 2 stroke | 17 | 10-09-2014 09:34 AM |
Oops, overheated ec300, what's the damage? | solstice | Enduro Engine - 2 stroke | 15 | 01-01-2014 04:42 PM |
Ec250 Cylinder Head Bolts? | Elliker | Enduro Engine - 2 stroke | 8 | 01-24-2009 04:51 AM |
Boot damage | jhendr3702 | General Discussions & Announcements | 3 | 11-08-2008 08:35 AM |
