Old 07-24-2017, 01:52 PM
Hofbuzz Hofbuzz is offline
Default GasGas 250 EC 2014 Nordic, flywheel removal
Turning the bolt clockwise or counterclockwise to loosen it.
Old 07-24-2017, 08:53 PM
The nut on the ignition side turns counter clockwise to loosen and remove.
I use this tool to keep the fly wheel and crank shaft from moving when breaking the nut loose: https://www.harborfreight.com/lockin...amp-36813.html
You will need a fly wheel puller to remove the fly wheel. Hope this helps.
Old 07-25-2017, 02:42 AM
Thanks
Old 07-25-2017, 04:48 AM
The crank nut on the other side of the engine (clutch side) is left hand thread, smothered in Loctite, and heavily torqued.
Old 07-25-2017, 06:31 AM
Do you know whitch thread theFLYWHEEL PULLER is 27*1 or 27*??
Old 07-25-2017, 12:02 PM
Neil E. Neil E. is offline
M27 x 1.0 LH thread on the puller
Old 07-25-2017, 01:58 PM
Thanks great
Old 08-11-2017, 12:42 AM
I have the answer now it?s RH.
Flywheel Puller External RH M27xP1.0 for (2014 ec250 nordic edition)
Old 08-11-2017, 10:56 AM
Interesting. There is obviously different ignitions on the newer bikes. My 2011 with Kokusan 2K3 is for sure M27x1.0 LH (I just got out the puller to confirm it).
Old 08-11-2017, 04:24 PM
I know my 2010 and 2013 both use LH, but neither have e-start. I think I recall n_green needing a RH puller.
He has a 2011E start and is was LH, and his 14 model is RH. I'm not sure when it all changed, but I think 14 went to a new crank so maybe that was the change point?
Tags
2014, flywheel, nordic
GASGAS EC 300 Nordic Racing ?HLINS BSM2 Pictures & Videos 0 05-18-2015 02:55 AM
flywheel removal.. kernow-valver Enduro Electrical & Wiring 5 03-23-2015 05:48 PM
Flywheel Removal BOBBYPRUIETT Enduro Engine - 2 stroke 3 04-08-2010 12:16 AM
Flywheel removal....Thread size. wence Enduro Engine - 2 stroke 4 12-12-2009 04:19 PM
Flywheel removal jyellard Enduro Engine - 2 stroke 4 03-20-2009 03:45 PM
