#21
I was going to ask the same thing. DATA. Give us your data.
'11 Husky CR150, '11 GasGas XC 300-E, '11 Kawasaki KX250F, '71 Hodaka ACE 100B+ |
#22
Shallower bowl designe lends itself, from the end users perspective , easier to access internals, cant speak for the engineers at Keihin's reasons. To high a float level for enduro, not street use has been a common problem with all gasgas carbs past and present and if looking as to the reason for atrocious fuel economy, it's the first place to look. You can adjust the revised float just like you would the earlyier versions by way of a tab. It became apparent right away that the 16 mm settings on the old carb was going to be a no go thats how I realised there was a float bowl redesigne. My float height setting of 8 mm is abritrary, 6-6.5 mm is Keihin spec to the best of my knowledge or you can use parallel seam on float body to carb body flange method. If it in my case it starves for fuel at sustained wot I will go back and adjust accordingly.
#23
I still don't have a clue how you adjusted it. There's no brass tabs to bend.
#24
No brass in mine either. Post up a picture so we can see what tab you are referring to.
#25
I'm on pins and needles waiting... tick tock tick tock tick tock.
#26
Just bend the friggin tab! I was out for two hours today bike ran perfect no starvation even on extreme grades, ,no pissing of fuel at high lean angles, rider not so good, send beer quick! PS no pics , carb is good enough and staying buttoned up till temp goes way up.Bike managed an inspired fourth gear power wheely with pickup truck load full of Native Americans taking exeption to territorial ingress.
#27
I haven't picked my 2011 300 up yet so I don't even know what size carb it has on it yet, but it sounds like the possibility of a 36 or a 38. I guess I could call the dealer and have him check. I've had pretty good success getting bikes jetted over the years, but I'm certainly no James Dean on it. Hopefully not a stupid question, but shouldn't a 300 come with a 38mm? I guess that may depend on what its intended use is, but I'm curious.
2011 Gas Gas EC300 38mm, 2008 Husky TE610, 2003 Beta Rev3 250 |
#28
I think it's a supply issue from Keihin. I'm sure they, Keihin dialed back or even stopped production of the two stroke carb after the big four stoped or limited production of two stroke bikes to concentrate on the fcr and fi.
#29
Could be, but I wouldn't think less demand would affect Keihin's ability to make a run of one size carb or the other if an order came through, as they have the tooling already. Seems strange they'd send some with one size and others different.
#30
My ASI it is very critical on how vertical you can get the carb. The throttle cable will get very tight the closer you get to vertical due to the tight fit under tank. Depending on how well I did with the many times I've taken it appart and put it together. The differnece from spilling fuel with the slightest tilt of the bike and it barely dripping is probably a few degrees. Always critical with these ASI or ASII, some KTM's Ive ownedhave ASII's but if yours is one degree off it could dump fuel with float height being just fine.
Track-N-Trail Cycle LLC trackntrailcycle.com 2011 Beta 400 RR (sorry ) 2010 GAS GAS XC 300 2007 KTM 200 XC |
300 2T Differences between 08' and 2011 ?? | husley | General Discussions & Announcements | 11 | 12-23-2010 10:31 AM |
´08 and ´09 differences? | vavido | General Discussions & Announcements | 3 | 11-10-2008 09:20 AM |
head differences 03-05 450? | Motarded1 | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 05-12-2008 01:02 AM |
head differences 03-05 450? | Motarded1 | Enduro Engine 4 stroke (including EFI & Exhaust) | 0 | 05-03-2008 07:43 PM |
Differences between DE and EC models | ScottyR | General Discussions & Announcements | 38 | 02-13-2007 06:40 PM |
