Old 09-13-2007, 09:40 PM
PEB PEB is offline
Default Upper shock mount
Is the upper shock mount pressed together? I have an 02 and at a minimum it needs new orings between the bushings and the shock body possibly the heim joint that is supposedly inside as well.
paul b
Old 09-14-2007, 02:33 PM
PEB PEB is offline
I took it apart last night. For those of you who are curious it is a heim joint, mine is in nice shape, with bushings pressed in from either side. The orings probably were fine, they will be new when I reassemble.
Paul B
08 top shock mount. nick790 Enduro Suspension 3 03-01-2009 03:46 PM
I've got the blessing from upper management! MattR General Discussions & Announcements 18 12-08-2007 12:58 AM
Bottom Shock Mount PEB Enduro Suspension 6 10-12-2007 04:13 PM
Upper shock mount PEB Enduro Suspension 1 10-02-2007 11:51 AM
Top shock bushing/mount 07 ohlins highspeedsteel Enduro Suspension 13 07-24-2007 07:53 AM
