Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Enduro Technical Forums > Enduro Product Announcements
Enduro Product Announcements Announce new gasgas enduro products here - Vendors Welcome...
Old 10-08-2012, 09:11 PM
Synergy-Seals Synergy-Seals is offline
Cool Synergy Seals NEW Fork Wipers
These new 48mm wipers fit Sachs and WP.
Nice and slippery with a very nice sharp lip. The color is blue.
Ready to purchase in a couple weeks
$24 per pair
Please call me for any questions
Dealers welcome.
www.synergyseals.com
209-938-9726
Being BOLD is BOLD! However, being confident is certain!
Ride with confidence again!
Made in the USA
Old 10-08-2012, 09:19 PM
GMP GMP is online now
48mm correct? Will they fit the new 48mm Zokes?
Old 10-08-2012, 09:24 PM
Glenn. I have not had the opportunity to check them with mrz forks. They slip right into kyb forks and will not work with kyb.
Wp wiper fit the same way with kyb....too loose.
Yes ....48mm....sorry
Do you have some forks apart to measure?
209-938-9726
Made in the USA
Old 10-09-2012, 12:32 AM
What is the difference between these and the previous ones? Are they any easier to slide into the outer tubes?
An off topic question, I have your flex seals and sliders in my forks and have about 30-40hrs on them with no issues (still no air buildup in the forks) and am about to change my oil and replace bushes, but while I have a spare set of seals I amreluctant to change them because I don't have enough time before the Roof to break them in-they started quite sticky-do you think I am taking a big risk?
Old 10-09-2012, 09:23 AM
Rob,
Well the KYB seals and bushings fit the new Zokes. I'm popping my wipers off this week to clean underneath, so I'll measue them plus the upper tube ID best I can. Those OEM Zoke seals are snug, ZERO, I mean no air buildup in the fork yet.
Old 10-09-2012, 09:43 AM
You will be ok to remove the flex seals without damaging them.....this is another great thing with these seals. You can reuse them over and over as long as they are not damaged.
Always imspect the od and id lips.
You will also find that they will be very smooth and slippery with no stiction issues and they will continue to not be "air suckers" like all other seals oit there.
Rob
209-938-9726
Made in the USA
Synergy Seals Fork Lower Guide Bushings Synergy-Seals Enduro Product Announcements 2 08-24-2012 12:14 PM
SKF Fork seals orangezuk General Discussions & Announcements 12 03-14-2012 10:29 AM
SKF Fork seals orangezuk Enduro Suspension 2 03-10-2012 05:05 PM
Fork Seals Brian Enduro Suspension 8 11-17-2010 04:11 PM
Fork seals Iron Hide Enduro Suspension 2 02-22-2008 12:45 PM
