#11
Marzocchi 48
#12
Speaking of forks, I have no idea which ones are on my 2001 EC 300. They're bleeding out pretty bad. It has the Ohlins rear shock, so would it most likely be Ohlins forks?
#13
They're Ohlins if they have gold fork tubes but most likely WP43 forks.
Noah 2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title 16' Ski-Doo XS Renegade X 1200 4T 16' Specialized Fatboy trail 02' ZRX 1200r R.I.P. 72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been) 15' TW200 |
#14
Still scratching my head for some information about this bike. Is there at least any online retailer listing good parts for the 2001 EC 300, in stock?
#15
Gas gas bendix
top gear teeth – 40 top gear width – 7mm top gear dia – 41.5mm top shaft dia – 8mm top shaft length – 9mm bottom gear teeth – 14 bottom gear dia – 28mm bottom shaft lenght – 7mm bottom shaft dia – 8mm nearest bendix match – smu5009 – 10mm thick top gear |
#16
Gas Gas EC 300 Rotor -
Kokusan FP8009 Possible crossover with ktm |
#17
Do you have picture you can show us? It probably has WP43 forks on it. Most of them were grey in color. KTM WP 43 seals will work. www.halls-cycles.com has a good supply of parts and has online access to part numbers.
#18
Check the clutch thread at the top of this forum, it has the part number
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
cross over parts 09 ec300 | kevin | General Discussions & Announcements | 7 | 11-23-2013 02:34 AM |
Cross over parts | Pepperami | General Discussions & Announcements | 3 | 11-10-2012 08:21 AM |
2006 ec200 parts cross over | chinesegav | United Kingdom | 8 | 08-20-2012 05:24 AM |
Cross referencing control parts. | Mick | Enduro Chassis & Body | 7 | 03-30-2012 04:59 PM |
Cross-over parts help | SpeedyManiac | General Discussions & Announcements | 9 | 03-01-2007 05:28 PM |
