#11
Off topic I know, just thought I might distract you for a minute? |
#12
Just because this leak is being such a pain in the butt, I would be pressure testing and finding the leak to know 100% what it is this time. Just in case there is a strange flaw / defect somewhere right?
How are the water pump bearings? It does seem odd to me that you would wear out the seal in such a small hour count.
2021 Beta 300RR 2014 Gasgas XC300R 2019 850 Pro RMK |
#13
I spoke with Halls and they said the only way for coolant to get into the crankcase was either a failed clutch cover gasket or a failed water pump seal. They said a cracked head or base gasket would not allow coolant to get into the crankcase and would cause other symptoms.
So while the pressure test overall is a good idea, it is almost pointless since I know it is not the clutch cover gasket, so it has to be the pump seal. Ordered a new pump rebuild kit, but this time with the bearings and shaft. Hopefully that fixes the problem for good, if not, then there are some other inherent problems in the case or pump casting, causing a recurring failure, in which I will just get rid of the bike all together. Last edited by 95jersey; 07-21-2015 at 04:07 PM. |
#14
If you have coolant in the transmission oil the only way it'll get there is if you have a serious casting issue in the cases, failed gaskets, or a pump seal failure. Head/Oring failure will show different signs including either losing coolant into the crankcase (bottom end - not tranny), or overpressurising the cooling system and blowing it out the overflow. It sounds like you've narrowed it down to the impellor seal, which makes sense if it did resolve for a period of time. Check the shaft well, make sure the new seal goes in safely, and I'd also spend some time checking the bearings it rides in and replacing if required. If the bearing has excessive play/tolerance and the shaft is allowed to move it could also wear the seal prematurely. |
First coolant change - $#%+ In coolant?? | Why Z? | Enduro Chassis & Body | 10 | 06-26-2014 03:32 PM |
mixing oils | gasser | Enduro Suspension | 5 | 09-21-2012 03:33 AM |
Overflow issue and bog | forgiven | Enduro Intake/Carburetion - 2 stroke | 4 | 10-05-2011 09:20 AM |
clutch issue | boostedte37 | General Discussions & Announcements | 2 | 11-09-2009 06:58 PM |
ec 400 gearbox issue | Paul Somerville | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 09-05-2009 10:17 AM |
