2004 Gas Gas 300ec new loom no spark !
Ok so ive just had the engine rebuilt becouse of water damage she was running sweet before that. Ive had the frame powder coated as well while its in bit
The loom was looking well past its sell by date so i gave it to a mate to make up a new loom as he does a lot of bespoke stuff for cars with good success .... While he was there he took out the indicator wiring and any other bit that was not needed .... he has replaced color with color and new plugs all round So yes you gessed it we have no spark so there is few question i need to know ! what color goes on the coil ? and what voltage readings should i be seeing out of the wires when i kick it over ? |
Powder coated frame may be your problem, make sure all your grounds are cleaned GOOD (as in grind the powder coat off)
Fred Overstreet 2010 EC250 SixDays 2004 GasGas EC300 -Sold to a good home 2006 GasGas EC250-Sold to a good home 2006 GasGas TXT 280 Pro |
Ive just got one ground, its under the coil at one end and yes i ground it off with a grinder ...
make sure you're engine is grounded out, on either the head stay or the bottom mounting bolts
Jack - western PA 2006 KTM 250 sx 2006 EC 200/ 11' style kit--GONE 2004 200 EXC 1997 KDX 220 2004 CRF 250X 1974 CL125 www.youtube.com/allthatstuff35 <---some gasgas videos here |
Ok will do the head stay as its easier to get at and i dont want to drain any fluids out ...
The head stay bars to the frame are aley is this still ok for grounding ? |
Depends which wire you are measuring the voltage from. Yellow from stator = ~7V White from stator = 9-12 V If you measure past the voltage regular you are only going to see 5-6V.
-Mike 2009 Beta Evo 300 4T - 1982 Suzuki PE175 |
Right made up two 7" earth straps. I removed the front engine stays to the front of the fame. Ground back to the metal and put a strap each side.
Still no spark |
Is this while im kicking it ? sorry electrics arnt my thing |
disconnect your kill switch.
i've seen that be an issue. how are you checking the spark? with a new plug grounded to the engine in the dark? with a meter?
2002 Husberg FE650e 2006 GasGas EC300 2014 Sherco SER300 2014 Beta Evo Factory 300 |
ive disconnected the loom to the kill switch still nothing , I turn the light off and ground the plug on a headbolt and the son tell me if he sees a spark while im kicking it
No Spark | fullthrottle | Enduro Electrical & Wiring | 9 | 12-31-2013 05:14 PM |
need laundry list for 99 300EC and 2000 300EC | steveola | "Wanted to Buy" & "Want To Trade" | 0 | 08-07-2013 12:50 AM |
can anyone help with wiring loom routing | dirtjunky_uk | Enduro Electrical & Wiring | 3 | 08-05-2011 01:04 AM |
CDI? No spark | tommymoto | Enduro Electrical & Wiring | 4 | 02-28-2011 01:22 PM |
