#11
The same thing happened to my 07 250. Pulled the carb and found "trash" in the bowl. Cleaned with carb cleaner and cleaned tank. I think I got some bad gas as the tank had a good bit of trash inside. After cleaning the carb no more problems.
#12
Well, after cleaning the carburetor, the power valve and repacking the silencer things changed a little for the better, or at least I think so. I'm starting to have doubts how did the motor actually run a month ago...
Anyway, the idle still is problematic. I tried making a short video, hopefully clear enough to understand the problem may be: http://www.youtube.com/watch?v=mIYgS5d5ekA The settings at the time of the video are: PJ 45 MJ 180 N1EF at second clip from the top Air screw between 0 and 3 turns (didn't notice difference in any position) Outside temp: 20-22 degrees Celsius (70-75 F) This morning I tried spaying again around the flywheel just in case, and don't notice change in revs. One other interesting bit: even at warm engine, it's hard to start it without the choke pulled. If choked, it starts first or second kick, if not, I can kick it all day probably. Still, if I open the throttle suddenly from idle, it bogs, which is sign for being rich, right? P.S. I guess this saga is turning into yet another 2-stroke jetting ordeal May be a moderator should split and move this thread? Last edited by Krasi; 05-27-2011 at 05:11 AM. |
#13
air screw no effect. needs choke to start warm bogs when throttle wacked. all of these point to these things: pilot wrong / float height wrong/ idle screw in too far / wrong needle diameter - one of these things is probably your issue. can you tune the bog when throttle wacked out with a/s position or no? with bike hot, try 1 turn/2 turn/3 turn and see if it has an effect...
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com |
#14
I put a slightly smaller pilot jet (42 vs. 45) and droped the N1EF needle all the way down. A/S is 2 turns out. Now, I think it works OK. Idles easily and smoothly. Responds properly to WFO throttle. Unfortunatelly won't be able to test it in a real ride probaby until next weekend, though.
Thanks for all the input. I've learned a lot during this week of troubleshooting. |
#15
mine idles exactly the same from what i can make of the vid.
my PJ is 40 and MJ 175 needle is N1EG and slide nr 7 adjusted to nr 9 (wich made a good difference. needle is set at it's lowest (leanest) starts very good when warm, cold is a litlle harder (+- 6 kicks). i am opening the engine to replace nescesary parts like mains , maybe con rod too... while i'm at it :-) |
Thread Tools | |
Display Modes | |
EC125 Power Valve and Oil | oldschool07 | Enduro Engine - 2 stroke | 11 | 09-27-2015 02:34 PM |
Power valve noise | rockrider1 | General Discussions & Announcements | 5 | 06-21-2010 02:55 AM |
Power Valve Removal | cdn280 | Enduro Engine - 2 stroke | 6 | 01-23-2010 05:34 PM |
Ohlins Base valve removal | PEB | Enduro Suspension | 5 | 09-01-2008 07:55 PM |
Power valve | bens25au | Enduro Engine - 2 stroke | 2 | 02-09-2008 11:02 PM |
