Headlight mount/rubber straps
Has anyone here removed the rubber straps from a headlight shroud without a) busting the headlight, or b) busting the shroud.
I have a spare 2013 shroud that I'm considering mounting to my 2018, keeping the actual headlight, indicators, etc clean and new. I don't use the light anyway. To do so I need to remove the rubber straps, without damage to either. The other option is I just order a second pair. Ref.BE25636015 |
A little silicone will help removing the straps.
'12 XC 200 TTX Sold '15 XC 250E Sale pending |
That's what I was thinking. Have some nice slick silicone grease here...
Sweet as. Bit of silicone and then a good push with the thumb should do it!
Turn the lights down, some smooth jazz,
I was waiting for you to chime in F5!
Headlight straps | BassMunn | Enduro Chassis & Body | 8 | 11-25-2016 04:18 PM |
headlight plastic/rubber strap fix | barossi73 | Enduro Chassis & Body | 2 | 06-01-2016 02:23 PM |
Headlight straps... | GGRider01 | Enduro Chassis & Body | 2 | 09-03-2015 09:58 PM |
Rubber straps | Rabbitist | Enduro Chassis & Body | 4 | 06-01-2011 05:10 AM |
