oil leak behind the sprocket
hi .
I have 300 that has oil leak behind the front sprocket .is there a cross part or is it just a gas gas seal? thanks |
Standard metric seal. I don't remember the size offhand, but look in the parts manual and the size is likely in the part description. The collar is a GG part though (inexpensive). Good idea to replace both as it grooves slightly over time. There is also an o-ring behind the collar that seals oil from leaking between the collar and shaft. Easy job with carefull use of a Craftsman seal puller.
thanks for the help
There is a sleeve seal and 2 o-rings on the shaft. There is an oil seal pressed in the case that seals against the sleeve seal on the shaft. I recommend replacing all of them at the same time.
Crank seal leak? | Dirt Addict | Enduro Engine - 2 stroke | 1 | 10-15-2009 11:34 AM |
Leak from around choke | PEB | Enduro Engine - 2 stroke | 0 | 08-16-2009 10:16 PM |
07 clutch leak | mountain thumper | Enduro Engine - 2 stroke | 6 | 07-06-2008 11:18 PM |
Voltage leak | nitroman | Enduro Engine 4 stroke (including EFI & Exhaust) | 8 | 04-13-2008 06:05 AM |
Gas cap leak? | colinmc400 | Enduro Chassis & Body | 6 | 05-21-2007 07:09 AM |
