Old 02-25-2020, 04:15 AM
2smokehaze 2smokehaze is offline
Default Cracked rear hub on 2018 EC300
Hey guys,
Just a heads up. I noticed slight play in my rear wheel after loading up the bike to go for a ride. Thought it was strange since the bike only has 70 hours of easy trail riding and never blasted the hubs with a pressure washer.
I found a crack on my rear hub (brake disc side) that has been letting water in and flogged out the bearing. It was full of rust, even the spring in the oil seal was pure rust. While staring at the hub face I notice one side was thicker then the other so it had been machined for the bearings and oil seal off-center. The crack developing on the thinnest part obviously.
Please check your hubs around the oil seal for cracks. Not sure if the off center machining on mine is a one off Monday morning or Friday afternoon job but check it out anyways. I wish I noticed it while I still had warranty.
It's my first time posting and have no idea how to post pics.
Old 02-28-2020, 10:42 AM
Shoot, that's a pain in the butt. Is it visible with the disk in place or do I need to take it off?
Old 03-04-2020, 05:03 AM
Sorry for the late reply.
Yeah big pain in the butt. I ended up getting it welded up for now. Having trouble finding an aftermarket hub for a decent price.
Its visible while still on the bike. Just spin the rear wheel while looking at the hub seal. I can email pics if you like or sms them to ya if you're in Australia
Old 03-05-2020, 09:35 PM
gasser's Avatar
gasser gasser is offline
I have a new oem (pre 2018) hub complete with bearings and inner spacers that I would sale for $150 plus shipping but you might have to swap out the spacers to make it work on 2018/2019 bike. This is probably the same hub but it will have a different part number because it is black. I could mount it on my lathe and sand and polish it smooth for another $25. This hub has never been laced up to a wheel.
Old 03-07-2020, 10:01 AM
I'll send you my e-mail addy via PN. Please send me the pics.
Ta Doc
Old 03-09-2020, 07:16 AM
2smokehaze sent me the pics.
Old 03-09-2020, 07:20 AM
I got mine welded up for now, I'm gonna see how it holds up. Thank you very much for the offer.
Old 03-09-2020, 09:05 AM
I have worn bearings on mine, might have to have a closer look...
Old 03-09-2020, 05:45 PM
shawbagga's Avatar
Mine is the same(2.5mm at top, 3.5mm at the bottom of hub) but not cracked after 260+ hours of logs & rocks. Will be keeping an eye on it.
'18 Gasgas XC250
Old 03-11-2020, 03:50 AM
Mines all good. Just shitty bearings and seals let go early. I?ll be putting some quality Japanese ones in and packing the hub full of grease.
Tags
2018, bearing, cracked hub, ec300
2018 EC300 Front and Rear Stock settings Gasser Nate Enduro Suspension 7 03-25-2020 11:04 PM
rear fender 2018 vs 2019 Doc Brown Enduro Chassis & Body 7 08-01-2019 07:43 AM
Cross Reference of 2018 GG KYB Rear Shock Bearing, Seals and Bushings emepher Enduro Suspension 2 08-31-2018 08:27 AM
2018 ec300 J. JuJu General Discussions & Announcements 3 07-17-2018 05:35 AM
2018 ec300 Fieds83 Enduro Engine - 2 stroke 11 07-11-2018 09:40 AM
