Old 03-06-2007, 03:45 AM
bxb's Avatar
bxb bxb is offline
Default Valve Help
Hi everyone, need some assistance with a valve check on an 06 pampera 400.
Can't seem to find the valve clearance figures or cam journal torque figures.
Doing the job is no problem, I just need the data. If someone can supply or point me in the right direction on the web I would able to do the job right and not have to worry about seizing the cam because I was too ham fisted on the torque wrench.
Two simple rules for dirt riding,
Right hand down, try not to die.
Old 03-06-2007, 04:25 AM
Sandman Sandman is offline
Inlet 6thou Exhaust 10thou , cam caps 10Nm
Put lots of oil on the caps before you put them back on
Old 03-06-2007, 05:31 AM
bxb's Avatar
bxb bxb is offline
Thanks mate, do you have a manual and if so, how did you get it.
VALVE adjustment west aussie gas 450 Enduro Engine 4 stroke (including EFI & Exhaust) 22 03-25-2013 02:50 PM
to valve or not to valve.... that is the dilema. dank Enduro Suspension 19 05-06-2010 07:41 PM
fse 400 valve timing ??????? mcludd Enduro Engine 4 stroke (including EFI & Exhaust) 4 08-29-2009 11:54 AM
400 fse cam/valve clearances captainslow Enduro Engine 4 stroke (including EFI & Exhaust) 4 05-26-2008 05:19 PM
pwr valve knock dustbuster Enduro Engine - 2 stroke 10 08-06-2007 01:36 AM
