MX style number plate on the '15
On my 06 I used a 08 CRF number plate when I had the OEM forks and triple clamps, and (obviously) a 2010 YZF plate on the Yzf KYB forks and triple clamps.
What do you guys use on the 2015 bikes for a MX number plate up front? Is it still the CRF that is the closest match?
I used a Honda numberplate with the gofasters mounting kit on my 2013. Worked pretty well for me. I have just run the headlight on my 2014.
the cycra stadium for a KTM works pretty good too. Small gap near the fender but it didn't bother me.
09 Honda plate. Then go to Home Depot and buy a $2 aluminum yard stick and make your own bracket instead of paying $50 for one.
Sent from my iPhone using Tapatalk |
99 EC200, want to change headlight to MX style plate. which one? | Jgracey | Enduro Chassis & Body | 3 | 04-12-2015 09:23 AM |
Number Plate for '12 | GMP | Enduro Chassis & Body | 1 | 04-03-2012 03:52 PM |
number plate | baker | General Discussions & Announcements | 5 | 01-24-2012 06:14 PM |
Number plate?? | nwcycle | General Discussions & Announcements | 2 | 05-24-2008 01:23 AM |
