Gas cap leak?
Out riding yesterday and i laid the bike down while i stepped off it . When i went to pick it back up, i noticed gas was leaking from the gas cap. I checked it was tight, then took it off and cleaned out round the tank and cap itself. When i refilled it at the halfway point, i noticed it was still coming out after a series of long, fast and deep whoops, where the bike was really bucking around.
Is there a known problem with this (as KTM have had with their 1/4 turn one) or is there a seal that can perish and may need replaced? Thanks |
What model and year of bike?
Took a real good look today and found a tiny hole in the top (black part of the tank) right next to the gas cap. Anyone think it might be possible for a spot of plastic welding??
how bigs the hole, can you just plug it iwth filler or something instead of going to all trouble of plastic welding??
get some epoxy or arildite that should do it
minds are like parachutes.....they only function when open |
I bought some so say "Plastic fuel tank putty" today. Seemed right for the job, but i followed the instructions and the stuff just seems way to dry to get in the hole and seal.
The hole is about 1mm wide and 2mm long. Areldite is next on the list if this doesn;t work. |
Crank seal leak? | Dirt Addict | Enduro Engine - 2 stroke | 1 | 10-15-2009 11:34 AM |
Leak from around choke | PEB | Enduro Engine - 2 stroke | 0 | 08-16-2009 10:16 PM |
oil leak behind the sprocket | quadinfamily | Enduro Engine - 2 stroke | 3 | 07-09-2008 11:57 AM |
07 clutch leak | mountain thumper | Enduro Engine - 2 stroke | 6 | 07-06-2008 11:18 PM |
Voltage leak | nitroman | Enduro Engine 4 stroke (including EFI & Exhaust) | 8 | 04-13-2008 06:05 AM |
