#11
I've had the same Scotts for 9 years on many bikes. Been rebuilt a few times and still works fine. The newer (current) GG tower #6265 is fine and does not slip. To seal the top bearing, use an o-ring and bevel washer like on the bottom bearing or if your tower was supplied with a shortened steel cup, use that with an o-ring underneath.
I can see an advantage to the sub mounts with the shorter tower being stronger, but I just don't like the bars that high. |
Thread Tools | |
Display Modes | |
RTT Steering Damper | iancp5 | Enduro Product Reviews | 3 | 06-15-2013 12:26 PM |
v2 Ohlins steering damper fit '07 EC 250? | rossrc | Enduro Chassis & Body | 3 | 09-15-2010 07:29 AM |
Steering Damper 2010 | swazi_matt | Enduro Chassis & Body | 0 | 07-11-2010 11:45 PM |
Motosportz steering damper | wence | Enduro Chassis & Body | 3 | 11-14-2009 05:33 PM |
Steering damper 05 FSE450 | McGuiver | Enduro Engine 4 stroke (including EFI & Exhaust) | 6 | 01-16-2009 11:18 PM |
